j-whitney
Message 1 of 7
Stats??
Just wondering why is my noise margin 15.5 when it use to be 12. its been like it for months now.
Line stateConnected
Connection time3 days, 07:12:02
Downstream8,128 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeInterleaved
Noise margin (Down/Up)15.5 dB / 24.0 dB
Line attenuation (Down/Up)6.6 dB / 2.5 dB
Output power (Down/Up)13.9 dBm / 1.7 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)105 / 91
CRC Errors (Down/Up)108 / 38
HEC Errors (Down/Up)1278 / 23
Error Seconds (Local/Remote)67 / 33
___________________________
6 REPLIES 6
Message 2 of 7
Re: Stats??
your stats look good - as you are on max speed for adslmax the additional noise margin is not a bad thing
j-whitney
Message 3 of 7
Re: Stats??
What about the errors?
Message 4 of 7
Re: Stats??
look ok for a connection time of 3 days.  mine is far higher than yours
if they were a problem you would have been disconnected by now
davesmeg
Message 5 of 7
Re: Stats??
I get more errors than that in under 4 hours.
j-whitney
Message 6 of 7
Re: Stats??
Yes your right. if I leave the hub all the time it stays connected for 20 days before a resync.
Guru
Message 7 of 7
Re: Stats??
As stated, connection's fine.   😉
