Lozzieb1989
Message 1 of 7
Steady blue light but can't connect
My home hub has a steady blue light but isn't showing up on my list of available connections. I've entered my phone number on the BT website but apparently there's no problems.
Tags (1)
6 REPLIES 6
john46
Message 2 of 7
Re: Steady blue light but can't connect
have you tried using an ethernet cable
Lozzieb1989
Message 3 of 7
No, I'll give that a try later.
5progface
Message 4 of 7
Had a similar problem just now at 0916.
The wifi light on my laptop went out.
Network diagnostics suggested "Verify Network Security key"  Verified it.
Then diagnostics found "A Network cable is not plugged in or is broken"  Not so cable is fine.
At 0920 the connection was Re-established, wfi light on laptop illuminated again.
No idea what caused it.
Lozzieb1989
Message 5 of 7
Very strange.  Mine hasn't been working since last night.
imjolly
Message 6 of 7
@Lozzieb1989
did you try resetting the hub using recessed button on back
Lozzieb1989
Message 7 of 7
No I didn't, I'll try that later too.
