Steve_P
Message 1 of 19
Sticky IP Profile after move to ADSL2+???
Hi,
Recently recieved an e-mail from retail migration on the 5th July to notify me that my network had been upgraded (21CN) and to tell me about the 10 day settling period. We have always had download speed of about 5/6Mps on a noise margin of around 9-12dB but our Home Hub 2 has always been a pain with multiple reboots every day (All lights going out) of its own accord.
Last week I noticed after another random reboot the noise margin shot up to 25dB whilst the speed droppd to 3Mps where it has stayed ever since.
After a bit of research I have cured the HH2 reboot problem (Disabling UnPn and switching to wireless B/G) and fitted an I-plate, but to date the noise margin has not shifted.
Hopefully this is just a case of a stuck IP profile the a helpful MOD can sort out? It's getting quite frustrating and I find myself getting quite obsessional with checking my router stats all the time!
ADSL line status
Connection information
Line state Connected Connection time  3 days, 12:32:12
Downstream  3,072 Kbps  Upstream  1,179 Kbps
ADSL settings  VPI/VCI0/38
Type  PPPoA
Modulation  ITU-T G.992.5
Latency type  Interleaved
Noise margin (Down/Up)  25.1 dB / 6.4 dB
Line attenuation (Down/Up)  35.0 dB / 19.9 dB
Output power (Down/Up)  0.0 dBm / 12.8 dBm
Loss of Framing (Local)  0
Loss of Signal (Local)  0
Loss of Power (Local)  0
FEC Errors (Down/Up)  0 / 0
CRC Errors (Down/Up)  217 / 2147480000
HEC Errors (Down/Up)  nil / 0
Error Seconds (Local)  211
Ps Conneted to master socket, no extensions and new filter fitted!
18 REPLIES 18
Message 2 of 19
Re: Sticky IP Profile after move to ADSL2+???
as you are on adsl2+ you are on the new profile system which is 88.2% of connectiojn speed and changes as speed chnages.  you profile is not stuck but it does look like you are in a banded profile due to all the disconenction/resets and as you have 3+ days connection it would normallly release in that period but yours appears stuck.  I would contact the mods to get you out the banded profile
contact mods
can take up to 3 working days for mods to contact you
banded profile is nothing to do with ip profile
Message 3 of 19
You have a very high SNR value. Are you connected to the test socket?
As Imjolly says you look to be on a banded profile, probably because of connection instability.
Message 4 of 19
I would not move your connection and remain with stability until the mods get you released from the banded profile then look at your connection if speed not as expected
Message 5 of 19
I fully agree with Imjolly just et the connection stabilise and wait until the mods get you released from the banding
Steve_P
Message 6 of 19
Thanks for the advice guys! I've conntacted the mods so we'll wait and see what happens.
Message 7 of 19
please keep us posted on your progress
Message 8 of 19
just patience as it appears from some recent posts that it is taking slightly longer than 3 working days before contacting you
Steve_P
Message 9 of 19
Just a quick update. No mod contact yet, but I've got some speed back!! Downstream noise is now 15dB so hopefully theres still a few Mbps to be had in time!
1. Best Effort Test: -provides background information.
 Download  Speed
 5.08 Mbps
0 Mbps7.15 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 5.08 Mbps
 For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
 IP Profile for your line is - 5.34 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.79 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.79Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Message 10 of 19
you have been released from the banding automatically and there is still more scope for a speed increase if you can get noise margin down to 6db  can you post new adsl stats please
