ziekasakura2
Message 11 of 30
Re: Still no fix
i found a reply in the email inbox, my dad had put it to one side in a seperate folder and forgot to tell me i will PM the incident number,
ziekasakura2
Message 12 of 30
Re: Still no fix
Just posting my hub stats after a day i unplugged the Sky HD+ Box line to the phone, in aid to narrow it down but i also changed network adapter at same time so i don't know what could effect it if either could.
Other thread: http://community.bt.com/t5/BB-Speed-Connection-Issues/Slow-speeds/td-p/241903/highlight/false/page/5
but here they are atm on the link above are the stats previous to unplugging the sky box (its in a large front room, and the box is on the other side of it to the hub)
ADSL Line Status
Connection Information
Line state:Connected
Connection time:1 days, 01:53:37
Downstream:5.031 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):11.9 dB / 22.0 dB
Line attenuation (Down/Up):32.6 dB / 18.0 dB
Output power (Down/Up):19.9 dBm / 12.5 dBm
FEC Events (Down/Up):165740 / 21
CRC Events (Down/Up):1 / 2
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 1
Error Seconds (Local/Remote):1 / 2
Sync speed should be higher, but i'm guessing due to the unstability of my line its dropped ?
Also my IP Profile has dropped and it hasn't even managed to reach the profile it should be at yet which is also fustrating.
Just another thing to mention i also mentioned the phone line from the sky box etc and even the engineer looked at the filter and said it was fine (new filter from hub 3) it is is the sky box phone line why hasn't the engineer mentioned this ?
again thank you for putting up with my fustration at this matter.
gouledw
Recognised Expert
Message 13 of 30
Re: Still no fix
If that happens may be worth getting a filtered faceplate, which basically doesn't include your internal wiring in any of the broadband signals. better all round 🙂
ziekasakura2
Message 14 of 30
Re: Still no fix
is that the v10 faceplate i hear being talked about sometimes
Message 15 of 30
Re: Still no fix
Hi your sync speed is lower as you have posted the reason is your noise margin has increased to11.9 from 5.4 once your line settles down that can be changed by the mods doing a reset for you
gouledw
Recognised Expert
Message 16 of 30
Re: Still no fix
Yup, http://www.run-it-direct.co.uk/BTNTE5ADSLfaceplate6way.html
if you can get a broadband engineer out they should be able to fit one for free. They're the creme de le creme 😉
revocomputers
Message 17 of 30
Re: Still no fix
99.99999999% you have a bad connection on your line, unfortunatly BT's test equipment is not good enough to detect this, so the engineer will tell you that your line is good.  I'm in the same boat as you and it's very frustating when you know what is causing the fault.  I've now been waiting a year to get mine fixed, but hopefully they will swap your whole line and that might fix it.
http://community.bt.com/t5/BB-Speed-Connection-Issues/BB-disconnects-when-phone-rings-had-18-BT-visi...
revocomputers
Message 18 of 30
Re: Still no fix
BTW, see if the program RouterStats will work with your router, it will record your noise margin
Message 19 of 30
Re: Still no fix
if it is a HH2 or HH3 routerstats does not work
ziekasakura2
Message 20 of 30
Re: Still no fix
Just caught it in the act, did a quiet line test, and im hearing a very very quiet hiss almost unoticeable, but when i pick up the cordless one taking into account the hum you get i can hear the noise clearly
Connection time:0 days, 20:38:45
Downstream:7 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):3.8 dB / 21.0 dB
Line attenuation (Down/Up):32.7 dB / 18.0 dB
Output power (Down/Up):19.9 dBm / 12.4 dBm
FEC Events (Down/Up):32356530 / 371
CRC Events (Down/Up):122717 / 284
HEC Events (Down/Up):687136 / 292
Error Seconds (Local/Remote):2963 / 445
This is the stats now as its happening and the FEC's Down are at least 10k per second and all speed and everything has dropped 😞
