Amunre
Message 1 of 10
Still stuck at 10.0 SNR Margin after 15 days
I'm still stuck with a 10.0 or thereabouts SNR margin after 15 days up time with no errors. Can anyone help to fix this so I can more closely achieve the target SNR of 6.0db please?
Thanks in advance
“Dogs come when they're called; cats take a message and get back to you later.”
Mary Bly
9 REPLIES 9
imjolly
Message 2 of 10
Re: Still stuck at 10.0 SNR Margin after 15 days
can you post your router adsl stats please
Amunre
Message 3 of 10
Sure, here goes
Model NameBiPAC 7800DXL
Host Namehome.gateway
System Up-Time17D 18H 33M 34S
Date/TimeSun Sep 13 15:11:45 2015
Software Version2.32d.dm12
LAN IPv4 Address192.168.1.254
LAN IPv6 Addressfe80::6203:47ff:fe10:3ec0/64
MAC Address60:03:47:10:3e:c0
DSL PHY and Driver VersionA2pD038f.d24m
Wireless Driver Version6.30.102.7.cpe4.12L08.4
WAN
Line Rate - Upstream (Kbps)448
Line Rate - Downstream (Kbps)1088
Default Gateway / IPv4 Addresspppoa0 (DSL) / 81.153.237.215
Connection Time17 Day(s) 18:32:53
Primary DNS Server213.120.234.170
Secondary DNS Server213.120.234.34
Default IPv6 Gateway / IPv6 Address
LAN Statistics
InterfaceReceivedTransmitted
BytesPacketsErrorsDropsBytesPacketsErrorsDrops
P4/EWAN00000000
P300000000
P23511468853651774002299280542503933900
P14631752903077614002098782718249517100
wl02975598821963058003716151481393307800
wl1269890717923007153339964244400
xDSL
xDSL
Bonding Line Selectionline 0line 1
ModeADSL_G.dmt
Traffic TypeATM
StatusUp
Link Power StateL0
 DownstreamUpstream
Line Coding (Trellis)OnOn
SNR Margin (dB)10.17.0
Attenuation (dB)62.031.5
Output Power (dBm)16.212.4
Attainable Rate (Kbps)1408652
Rate (Kbps)1088448
K (number of bytes in DMT frame)3515
R (number of check bytes in RS code word)1616
S (RS code word size in DMT frame)4.004.00
D (interleaver depth)84
Delay (msec)8.008.00
INP (DMT symbol)0.410.13
Super Frames
There they are.
Mary Bly
imjolly
Message 4 of 10
see if mods can reset your noise margin back to 6db which will give a bit more conenction speed  mods will post a contact us link
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
NeilO
Moderator
Moderator
Message 5 of 10
Hi Amunre,
Please use the 'contact the mods' link in my forum profile under the 'about me' section to send in your details and we'll be happy to help. You can find the link by clicking on my username.
Neil
Amunre
Message 6 of 10
Hi again,
Update on my problem:
On Tuesday 15th Sep, a lady operative from BT called to say that she was "resetting my line". I checked router stats at 13:50 and noted that SNR was 1.1dB. BTW speed test gave a download speed of 1.81Mbps and an upload speed of 0.38
At 16:15 SNR was 1.1dB with a download speed of 1.58Mbps and an upload speed of 0.38Mbps.
The operative said she would call back this morning (Wednesday 16th) to see how things were.
Checked stats at 09:00. SNR was 0.8dB, download was 0.61Mbps, upload 0.35Mbps.
Checked again at 09.30. SNR was below 0.0 and unable to access web pages.
Called BT Broadband faults, who monitored line and access was restored about 10:30.
Status as of 11:30: SNR 1.1dB, Download 1.81Mbps upload 0.37Mbps.
Although original operative has yet to call back, am happy with current situation.
Thanks to one all for interest in this particular fault.
John F
Mary Bly
john46
Message 7 of 10
your noise margin is far to low it should be 6dB your problems are being caused by the low noise margin
Message 8 of 10
As john46 has stated, I think trying to fix your noise margin to 6 dB by disabling DLM is going to cause problems, I remember trying to do this with my previous ISP and my noise margin would just fall from 6 dB to less than 1 dB during the evenings and my router would continually resync. Maybe you could try a higher noise margin of 9 dB or just let DLM do it's thing and try and keep your line stable even if it means your noise margin rises back to 10 dB.
Amunre
Message 9 of 10
As BT Northern Ireland reset my SNR, I am going to leave things well alone. Currently my download speed is 1.52Mbps and upload is 0.37 Mbps. with an SNR Margin of 1.0dB. Which I'm quite happy with. As you suggest I am just going to let the DLM "do it's own thing" and wait for the line to fully stabilise and see what develops. BTNI are going to ring me next Monday so hopefully things won't go awry before then.
Mary Bly
john46
Message 10 of 10
in that case just hope in does not disconnect at night as may well happen with such a low noise margin
