chainsawdude
Message 1 of 11
Stop the god **bleep** throttling
Ive had enough of this bull**bleep** throttling at evenings, i rerely download things these days and my connection is used only for watching videos on youtube and for my sons xbox, yet in evenings i cant watch a video without the **bleep** thing buffering every couple of mins, stop throttling my connection for watching **bleep** videos on youtube.
10 REPLIES 10
chainsawdude
Message 2 of 11
Re: Stop the god **bleep** throttling
Since when did D A M N become a bad word that needed to be censored? M O R O N S 😞
Message 3 of 11
You are not being throttled unless you are using any p2p protocols
If you post your hubstats and a speed test then one of the community members can help you
Gigabit
Message 4 of 11
Have you run a speed test to see what speeds you get? Please use speedtest.bbmax.co.uk or speedtest.net because the BT speed tester is having issues at the moment.
Distinguished Guru
Message 5 of 11
BT doesn't throttle anything except P2P networks.  However, you may be suffering from network congestion, or else your connection may just be too slow for what you want to do.
paulc_dj
Newbie
Message 6 of 11
So do they throttle or completely stop torrent useage?
Message 7 of 11
p2p is managed during peak time and all weekend - not blocked
Message 8 of 11
As has been posted before P2P is capped at peak times and weekends
chainsawdude
Message 9 of 11
Download speedachieved during the test was - 3.62 Mbps
 For your connection, the acceptable range of speeds is 600 Kbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 7.15 Mbps
ADSL line status
Connection Information
Line stateConnected
Connection time0 days, 03:12:18
Downstream8,128 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeInterleaved
Noise margin (Down/Up)6.8 dB / 26.0 dB
Line attenuation (Down/Up)14.5 dB / 6.0 dB
Output power (Down/Up)12.8 dBm / 1.9 dBm
chainsawdude
Message 10 of 11
Every single day i get buffering on youtube usually around 8pm till after midnight, even if it is congestion surely with 3.62mbps videos from youtube should play without a problem?
Either way, i am **bleep** off with it and want something done about it.
