Dragdy
Newbie
Message 1 of 3
Strange broadband speed drop
Hello
Since Monday I've noticed sudden drop in my broadband speed. Usually I've been receiving 80-120kbps but since Monday it is only 15-21kbs. I did everything they saying about improving broadband speed and it is not working. Strange thing  for me is that Hub stat showing good downstream:
ADSL line status
Line stateConnected
Connection time0 days, 0:45:30
Downstream1,792 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)9.8 dB / 17.0 dB
Line attenuation (Down/Up)59.0 dB / 31.5 dB
Output power (Down/Up)16.9 dBm / 12.4 dBm
Loss of Framing (Local)15
Loss of Signal (Local)2
Loss of Power (Local)0
FEC Errors (Down/Up)67106 / 0
CRC Errors (Down/Up)4583 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)7
But I still can download with max 21 kb/s.
What's more I did speed check via BT web site and did WCC test (whatever it means) and I received following info:
FAQ
Results Image not loaded
 WCC Assured test InConclusive.
Your WCC service was found to be performing poorly. Please raise a fault with your service provider, stating that the BT Performance Tester tool indicates
poor service throughput performance.
2 REPLIES 2
Guru
Message 2 of 3
Re: Strange broadband speed drop
Hi Dragdy
Did you notice what your present IP profile is set to?....
I'm betting it's come down, because you have loss of signal after only a 45 minute connection time.
A BT speedtest ..  will tell you :  http://www.speedtester.bt.com/
Dragdy
Newbie
Message 3 of 3
Thank you.
I called Bt meantime and there is a fault somewhere on my line. So They trying sorted it out.
Oo... and there is only 45min because I reset the Hub to factory settings.
