vaewin
Message 1 of 2
Strange event logs - constant open and close ports HH5
Can anyone tell me what this means and if I should be worried?
I factory reset the hub a while ago and noticed this in the logs.
19:10:12, 26 Sep.IN: ACCEPT [54] Connection opened (Port Forwarding: UDP [192.168.1.64]:58485 <-​-​> [snip]:58485 -​ -​ -​ [109.104.189.11]:25381 ppp3 NAPT)
Which goes on for many pages probably about 20 connections per minute with various IP addresses.
192.168.1.64 is a Macbook if that is of any interest, but the logs still show connections open and closed even when it wasn't connected to the hub?
Here's the helpdesk page
1. Product name:BT Home Hub
2. Serial number:+068343+NQ40907412
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 23/06/15
4. Board version:BT Hub 5A
5. DSL uptime:3 days, 22:04:19
6. Data rate:19999 / 71851
7. Maximum data rate:24497 / 71748
8. Noise margin:15.1 / 6.4
9. Line attenuation:8.9 / 9.9
10. Signal attenuation:8.9 / 9.9
11. Data sent/received:4.4 GB / 21.7 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:YoloSwag2k15
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 300 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:YoloSwag2k15.5
19. 5 GHz Wireless connections:Enabled (802.11 a/n (up to 217 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:34:8a:ae:b1:23:f6
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
1 REPLY 1
pippincp
Sage
Message 2 of 2
Re: Strange event logs - constant open and close ports HH5
I would check your PC for a virus/malware as the IP originates in the Ukraine. A company called Wildpark, ring any bells?
