Message 11 of 29
Re: Strange events in homehub 5 log but got speed increase? New firmware 1.7 maybe ?
How do I found out which firmware version im on?
oh nevermind, found it:
3. Firmware version:Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 27/12/13
Expert
Message 12 of 29
Mine has kept rebooting for no reason for the last 3 days so I have factory reset it and restored my configuration file which I backed up before all the reboots, lets hope this solves the rebooting issue.
Message 13 of 29
I've also hard factory reset my hh5 aswell, been stable for the past 12 hours...
Expert
Message 14 of 29
45 minutes shy of 24 hours up and no disconnections so far *touch wood*
Looks like a factory reset is in order for those effected by this issue, thankfully I had a config backup from before it went breasts up so nothing lost 😄
Message 15 of 29
Not sure if hard reset made any difference but after the hard reset, it disconnected once again but reverted back to normal speeds:
Connection time:0 days, 16:25:22
Downstream:43.62 Mbps
Upstream:7.989 Mbps
Message 16 of 29
It is intensely annoying particularly as trying to work from home and the router keeps rebooting.  I can see why some people prefer to run their own routers to avoid BT from remotely messing about at the worst times!
Message 17 of 29
My hh5 worked well for weeks until this week looks like this pushed test firmware 1.7 is to blame that's never seen light of day, hub has rebooted 3 times weds 2 times yesterday and this morning it had only been up and running 12 hours and reboot again the only lucky thing does not seem to have effected my speeds as yet still at 68 down 19 up lets see if the hub can run for all of 24 hours without bt messing with it I doubt it ?
Message 18 of 29
My download speed is fine but my upload speed has dropped from 11mb to 7mb.
Message 19 of 29
oh **bleep**.... after power cycling my hh5 download speeds have shot up again, meaning it's going to be unstable again!
Downstream:48.81 Mbps
Upstream:8.056 Mbps
Expert
Message 20 of 29
Sure its not to do with your HH5 being CFW?. How did you get your stats from the test.package 1.7, if its not CFW?. Mine updated but back in December had no issues at all also cannot find any of the sats you have copy & pasted on my HH5 page. You do know its a bad idea CFW your HH's if that is what you are doing to them. You could never get a replacement if it went wrong also cannot BT do something for example terminate your contract with immediate effect if they found out?, cause I should imagine they would find out if you needed a replacement and had to send it back or an engineer visit was necessary. I dont know if this is a fact at all by the way but I would imagine BT themselves read these threads.
Please click on white star to the left and say thanks if I have helped you at all!. 🙂 Thank you. Some handy links Copy & Paste:-
http://bthomehub.home/
http://netalyzr.icsi.berkeley.edu/index.html
http://diagnostics.bt.com/login/?workflow=Speed
