durandal_x85
Message 1 of 2
Strange phone problems
I have phone and broadband with BT. This morning after recieving a phone call I tried to hang up the phone but wasn't able to. Since then when I try to dial out I get dial tone but the key tones and ringing are very faint. When I can the landline from my mobile the phone rings normally. However, when I pick up either end I only get a lot of buzzing and a distant engaged tone. I've tried a different corded phone and there's no difference. It's plugged into the master socket and there isn't any damage. The strangest thing is that my broadband coming over the same line is working flawlessly. I reported this to BT first thing this morning but haven't heard anything back and the online fault tracker hasn't changed since then either. Does anybody have any idea what could be causing this?
Any help or advice is appreciated.
1 REPLY 1
StuartH
Moderator
Moderator
Message 2 of 2
Re: Strange phone problems
Hi Durandal_x85
Have you received any updates on the fault you have reported?
If not, please send us an email using the contact the mods link in my profile.
Stuart
