onedesigntalk
Message 11 of 13
Re: Streaming BT Sport from iphone to TV help
You need to use the specific cable for your model iPhone and model TV for this to work. Also it is not a exact mirror of your iPhone it uses only photo apps and video apps.
http://connect-to-tv.blogspot.com/2014/02/connect-iphone-to-your-tv.html
Jontizick
Message 12 of 13
I have Apple TV but it won't stream to it... Usually on iPhone there's an option to stream to Apple TV... This isn't on the bt sports app
Telecom89
Recognised Expert
Message 13 of 13
I can stream from iphone to apple tv without a problem. Have tried with an iphone4 and iphone5 both running ios 7.
When I select the programme that I want to watch and see it streaming on the phone then the button that allows you to send the stream to the apple tv appears, next to the audio volume setting. The button doesn't appear otherwise. Do you still have this problem?
