Message 1 of 8
Streaming issues on Unlimited Broadband with BT Infinity 1
General browswing and downloading fine but streaming issues on all PCs/TVs (wired connection) from, e.g. iPlayer.
Freqeunt pausing or 'Content unavailable now' messages.
Hope someone can help. Thanks!
Speed test results
D/L 49.49
U/L 17.39
Ping latency 21.88
Information from router:
1. Product name:BT Home Hub
2. Serial number:+068543+NQ51914663
3. Firmware version:Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 11/07/17
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 20:14:44
6. Data rate:19978 / 67742
7. Maximum data rate:24939 / 70211
8. Noise margin:8.2 / 3.2
9. Line attenuation:17.3 / 16.8
10. Signal attenuation:17.1 / 16.8
11. Data sent/received:60.7 GB / 131.4 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:No
14. 2.4 GHz Wireless network/SSID:BT2G
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:6
18. 5 GHz Wireless network/SSID:BT5G
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:XXXXXXXX (obliterated by me)
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
7 REPLIES 7
Message 2 of 8
Re: Streaming issues on Unlimited Broadband with BT Infinity 1
btspeedtester has been having some problems with low speeds so can you run thsi one and post results  http://beta.speedtest.net/
are you using wifi or ethernet connection?
Message 3 of 8
Thanks for answering.
All wired connections.
D/l: 49.40Mbps
U/l: 18.43Mbps
Message 4 of 8
with 49.4 Mbps you should not have problems streaming  are all your machines conencted by ethernet to hub - not powerline adapters
what have you tried yourself
out of curiosity have you tried wifi to see if any different
Message 5 of 8
Thanks. I have powerline adapters in operation but not on the machines in question which are all connected directly to the hub.
I've tried clearing flash storage and using different browsers.
Wifi - not sure as hardly use it except to stream local video on NAS, e.g. via VLC, which usually works reasonably as long as files are not too large.
Message 6 of 8
How many powerline adapters, and how are they connected?
Try disconnecting them from the home hub, and see if it help with the streaming on the other directly connected devices.
Message 7 of 8
I will do this. But they've been operating on my network for ages and the problems with streaming are recent.... (I appreciate they could still be causing a problem but feels less likely)
Message 8 of 8
If they are returning a lot of errors back to the home hub Ethernet port that the master powerline adapter is connected to, then it will have an adverse effect on all the other ports.
