I have just had BT Infinity switched on and speeds are really good. The Issue I have is that when I started using my Xbox one when it was first activated I had open NAT. Now I have just went to Strict for no apparent reason. I have googled and searched on here but found nothing for the Smart Hub. I have went into settings and changed my IP settings on the HUB to always use this IP address. The moment I save and go back it changes back to original setting of NO. Is this a common issue and why does my hub not save the settings? Any help would be appreciated.
Is there anyone that can help me with my Strict NAT issue that I am still having with my Smart Hub.
I have searched the boards but there is nothing for the Smart Hub. I have went into Firewall settings and put my Xbox one into DMZ but it is still strict. When I unplug my console and switch back on it goes back to OPEN but keeps going back to STRICT again after playing console over a few days. Thanks
I'm having the same issue, I have tried the above added ports and nothing...
i have 3 x box ones all running on smarthub with open nat and i did nothing to get it apart from checked my ip adress sharing http://bt.custhelp.com/app/answers/detail/a_id/44044/~/ip-address-translation%2Fsharing
