Benridley
Message 1 of 5
Stuck IP Profile?
Hi guys,
So I had a few problems with my broadband earlier in the year, 3 engineer visits and finally all sorted (problem with equipment in the cab).  Up to 8mb line now, all been great for last 6 months, dl of 6.6 mb/s give or take.
A couple of weeks ago I was getting disconnected very regularly, it was about the time of the crazy weather we had so I wondered if it was that which caused it, anyway after a few days of that it settled down but I soon realised my IP profile had dropped to 2mbps, and it has stayed there since.  I left it connected for about a week and it still didn't go back up, my connection did drop very briefly a couple of days ago so I'm not sure if there is still a problem with the line or if the profile is just stuck?  I'm also getting some extremely brief disconnects, particularly while on xbox live, but I think this is a coincidence, just more noticeable then!
Thanks in advance for any help/advice, you were all really great last time!!
Results:
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download  Speed
 1.95 Mbps
0 Mbps2 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 1.95 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2 Mbps
ADSL line status
Connection information
Line stateConnected
Connection time1 day, 13:05:57
Downstream8,128 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeFast
Noise margin (Down/Up)8.1 dB / 23.0 dB
Line attenuation (Down/Up)18.0 dB / 10.5 dB
Output power (Down/Up)19.8 dBm / 11.9 dBm
Loss of Framing (Local)0
Loss of Signal (Local)6
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)143 / N/A
HEC Errors (Down/Up)N/A / 2
Error Seconds (Local)601
4 REPLIES 4
john46
Message 2 of 5
Re: Stuck IP Profile?
You need to maintain 3 days + stable connection to allow your IP Profile to rise automatically if after 3 days it has not risen then please post back and wee can help you escalate it further
Benridley
Message 3 of 5
Ok well I am back to over 3 days constant connection, still no change, IP profile still 2mb.
Here are the hub stats:
Line stateConnected
Connection time3 days, 19:06:43
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Latency typeFast
Noise margin (Down/Up)7.5 dB / 23.0 dB
CRC Errors (Down/Up)309 / N/A
HEC Errors (Down/Up)N/A / 4
Error Seconds (Local)760
Keith_Beddoe
Message 4 of 5
If you would like to contact one of the UK based BT Care Team who moderate this forum, they should be able to help you.
They can be contacted using this link BT Care Team
They normally respond by phone or e-mail, within three working days, however you should get an immediate confirmation, with a tracking number.
Benridley
Message 5 of 5
Ok will do, thanks for the quick reply!
Ben
