Hi again
after 4 months of consistent broadband speed since my IP profile was stuck at 2 Mbps, it seems to have got stuck again. Here's the data
Download speed achieved during the test was - 1.85 Mbps For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps. Additional Information: Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM) IP Profile for your line is - 2 Mbps |
ADSL Settings
Azzmor
Hi
I am sorry to see you are having problems with your BT Service
I suggest you contact the forum mods they should be able to get this problem sorted for you this is a link to them http://bt.custhelp.com/app/contact_email/c/4951
They normally reply by email or phone directly to you within 3 working days they will take personal ownership of your problem until resolved and will keep you informed of progress
They are a UK based BT specialist team who have a good record at getting problems solved
This is a customer to customer self help forum the only BT presence here are the forum moderators
Thanks for the quick reply, I shall contact the mods, they resolved it quickly last time.
Thanks again
Azzmor
