Nickaminsky
Message 1 of 29
Stuck Profile
Hi I believe I have a stuck profile. Normally I get a sync rate of around 20mbps and noise margin of around 3-6db and the line is usually stable for at least 7 days.
Since the bad weather we've had it seems my line had been dropping and I've been shifted onto a slower profile. It managed to be stable for 5 days and then dropped again, here are the current stats:
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 00:09:06
Downstream:14.74 Mbps
Upstream:1.132 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):12.2 dB / 6.4 dB
Line attenuation (Down/Up):19.0 dB / 10.3 dB
Output power (Down/Up):20.4 dBm / 12.1 dBm
FEC Events (Down/Up):1180 / 0
CRC Events (Down/Up):0 / 33
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 7
Error Seconds (Local/Remote):0 / 0
 Download speedachieved during the test was - 13.23 Mbps
 For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
 IP Profile for your line is - 13.32 Mbps
Upload speed achieved during the test was - 0.95Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
I will leave this to see how long its stable for and then post the stats and perhaps one of the mods can kindly follow it up.
Cheers.
28 REPLIES 28
imjolly
Message 2 of 29
Re: Stuck Profile
there is nothing wrong with your profile as that is determined by your connection speed and is 88.2% of connection speed.  to get a higher profile you need a faster speed.  as you connection has been dropping this has resulted in your noise margin increasing to 12.2db and your connection speed reducing to 14.74mb
you now need to maintain a stable connection for 3+ days and then rpost your adsl stats and mods will help by resetting noise margin back to 6db  if your line then remains stable the DLM may reduce it to the new norm of 3db for good stable lines with no noise problems
Nickaminsky
Message 3 of 29
Re: Stuck Profile
Hi. Stats so far:
ADSL Line Status
Connection time:3 days, 05:03:30
Upstream:1.132 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):12.3 dB / 6.0 dB
FEC Events (Down/Up):92181623 / 96
CRC Events (Down/Up):9889 / 58
HEC Events (Down/Up):3512 / 31
Error Seconds (Local/Remote):5273 / 16
imjolly
Message 4 of 29
Re: Stuck Profile
connection looks stable so mods will help by resetting your noise margin which will increase your conenction speed
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 3/5 working days either by phone or email
NeilO
Moderator
Moderator
Message 5 of 29
Re: Stuck Profile
Hi Nickamisky,
If you click on my username you'll see the contact the mods link and I'm sure we'll be able to help you get this sorted.
Neil
Nickaminsky
Message 6 of 29
Re: Stuck Profile
Hi. I had BT contact me 10 days ago and said they had reset the noise margin. I left the home hub for 14 days stable and its now reset, but the noise margin is still stuck the same:
ADSL Line Status
Connection time:0 days, 00:01:56
Downstream:14.68 Mbps
Upstream:1.11 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):12.4 dB / 6.5 dB
Line attenuation (Down/Up):19.0 dB / 10.2 dB
Output power (Down/Up):20.4 dBm / 11.8 dBm
FEC Events (Down/Up):528 / 437
CRC Events (Down/Up):0 / 52
HEC Events (Down/Up):0 / 10
imjolly
Message 7 of 29
Re: Stuck Profile
did you follow the mods contact us link and complete the email?
Nickaminsky
Message 8 of 29
Re: Stuck Profile
Yes of course. I was contacted by David Moon on the 19th:
Hi Nick,
Thanks for taking my call today. As discussed, I’ve placed the order to reset the SNR margin which can take up to 10 days to complete so can you try checking that and get back to me as soon as you see any changes.
Regards
David Moon
john46
Message 9 of 29
Re: Stuck Profile
as David posted re contact him and tell him noise margin has not changed
Nickaminsky
Message 10 of 29
Re: Stuck Profile
Yes, have done. Thanks
