JoyceB
Message 1 of 4
Subtitles not working on Universal channel
Hi,
Just to report that the subtitles have stopped working on Universal channel.
Can someone fix it please?
Thanks,
Joyce.
3 REPLIES 3
PaddyB
Moderator
Moderator
Message 2 of 4
Re: Subtitles not working on Universal channel
Hi JoyceB,
Sorry to hear you’re having problems with the subtitles on the Universal Channel.  I’ll get our technical teams looking at this right away and I'll back back as soon as I have an update.
PaddyB
RobbieMac
Moderator
Moderator
Message 3 of 4
Hi JoyceB,
We’ve followed up on this with the technical team and uncovered a configuration issue with subtitles in certain scenarios.  We’ve fixed this now so you should be able to access subtitles again – do let us know if you have any further problems and thanks for your patience.
Cheers,
Robbie
JoyceB
Message 4 of 4
yes - working again now, thank you.
Joyce
