Message 11 of 16
Re: Sudden Drop (Again) in Infinity 1 Speed Moderator Assistance If possible
You may very well be right there!
Message 12 of 16
as quiet line test is ok have you tried connecting to the test socket with a filter and see if that improves your connection/attainable speed by eliminating any problems with internal wiring and faceplate  can you post new stats from test socket
Message 13 of 16
Message 14 of 16
Already done - stats  identical to the one's I posted.
Message 15 of 16
even the attainable and noise margin?  if so then looks like you now have reached your line potential
Message 16 of 16
Maybe, but why the sudden drop of 15Mbps? Have been getting a constant 45Mbps since got the HH6 early Jan.
BT are (again) insistant there is a fault and when I ran the online diagnostic that also reported back a fault - although how reliable that is I don't know.
Have been having these issues off and on for five years now.
