crd1904
Message 21 of 54
Re: IP Profile
So it can fall after a router restart basically? Am I to expect this trouble everytime the router is restarted eg after a powercut? Or is it only ffected by repeated restarts - as I have done recently due to airprint problems (now solved!)
Message 22 of 54
Re: IP Profile
with adslmax if you restart your router at a lower speed or the connection drops to a lower speed then your profile will drop immediately as per the chart I posted.  however if your router reset again and reconnected back to say 'normal' speed your profile will take 3/5 days to get back to correct level assuming you remained conencted 24/7
crd1904
Message 23 of 54
Re: IP Profile
Result! Noise margin is now 6 and IP Profile is 4.5!!!!! One thing puzles me. My current router data is below. It would appear that the router was restarted just over 4 hours ago but don't know by whom. Certainly wasn't anyone in the house! Does it get restarted whenever the noise or IP Profile is altered? Im not complaining - t's the fastest I've ever had. Thanks for all your help.
Message 24 of 54
Re: IP Profile
either noise margin or ip profile change will cause router to drop conenction and restart
can you post your new stats please
crd1904
Message 25 of 54
Re: IP Profile
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 04:41:54
Downstream:5.125 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):5.3 dB / 25.0 dB
Line attenuation (Down/Up):48.2 dB / 31.5 dB
Output power (Down/Up):19.5 dBm / 12.2 dBm
FEC Events (Down/Up):0 / 998
CRC Events (Down/Up):22733 / 1489
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):204738 / 457
Error Seconds (Local/Remote):2656 / 207
Message 26 of 54
Re: IP Profile
keep a check on the errors crc/hec as they are high for such a short tme connected and may effect your throughput speed.  if you find browsing getting slow at night then a change to interleaved from fast will help
crd1904
Message 27 of 54
Re: IP Profile
Fast has changed to Interleaved but error figure is higher. Download speed remain good though. ANy ideas? Router still resets itself quite frequently it seems. Regards
ADSL Line Status
Connection time:0 days, 01:08:33
Downstream:5.25 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Interleaved
Noise margin (Down/Up):6.0 dB / 25.0 dB
Line attenuation (Down/Up):48.3 dB / 31.5 dB
Output power (Down/Up):20.1 dBm / 12.4 dBm
FEC Events (Down/Up):812360 / 70
CRC Events (Down/Up):692 / 98
HEC Events (Down/Up):1652 / 73
Error Seconds (Local/Remote):13034 / 334
Message 28 of 54
Re: IP Profile
fec errors are not a problem as that is expected with interleaved.  just watch the crc/hec errors and error seconds.  I don't think the errors seconds didn't reset so not correct
crd1904
Message 29 of 54
Re: IP Profile
I don't know whats happening now! This is the latest. Is there any way the mods can sort this out please?
ADSL Line Status
Connection time:0 days, 06:00:52
Downstream:2.594 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Noise margin (Down/Up):18.8 dB / 24.0 dB
Output power (Down/Up):18.9 dBm / 12.3 dBm
FEC Events (Down/Up):2005334 / 191
CRC Events (Down/Up):6838 / 193
HEC Events (Down/Up):65772 / 170
Error Seconds (Local/Remote):13863 / 554
 Download speedachieved during the test was - 1.9 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :2.66 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2 Mbps
Should this be happening so often? Don't understand why it can't stay stable once it seemed to have settled?
Message 30 of 54
Re: IP Profile
looks like the errors have greatly increase and the automatic reaction is to increase your noise margin and drop your conenction speed.  are you still in the test socket?  is quiet line test ok?
