Message 41 of 54
Re: IP Profile
if you connect wires back as you describe apart from the wire on terminal 3 which should not be reconnected as that is the bellwire and can cause noise problems with your conenction.  you should also detach it in all other sockets.
if you can now maintain a stable connection 24/7 for 3/5 days then profile will recover to the correct value for your conenction speed
crd1904
Message 42 of 54
Re: IP Profile
Ok great. So can I detach the bell wire now or will this cause problems if I dont detach it from the other sockets at the same time?
Message 43 of 54
Re: IP Profile
just detach it and then other sockets asap - detaching is ok
crd1904
Message 44 of 54
Re: IP Profile
Thanks so much for your help and patience! Hopefully I won't have to bother you again 🙂 Best.
Message 45 of 54
Re: IP Profile
just post back when you can with new stats to show if line stable, noise margin ok and errors reduced
crd1904
Message 46 of 54
Re: IP Profile
Will do thatnks. Is it ok to get a few errors? Or should they all show 0/0
Message 47 of 54
Re: IP Profile
errors are expected just when you get toooo many then either line resets or throughput is reduced - so just check crc/hec errors and error seconds - fec errors are ok
crd1904
Message 48 of 54
Re: IP Profile
Latest seem to show improved everything. Now just waiting for the IP Profile to return to about 5 and I'll be very happy!
 Download speedachieved during the test was - 1.92 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :5.44 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2 Mbps
DSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 03:34:58
Downstream:5.313 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):6.1 dB / 23.0 dB
Line attenuation (Down/Up):48.2 dB / 31.5 dB
Output power (Down/Up):19.9 dBm / 12.3 dBm
FEC Events (Down/Up):70021 / 0
CRC Events (Down/Up):7 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):18 / 0
Error Seconds (Local/Remote):117 / 50
I presume the restart is due to the noise margin changing? Regards
crd1904
Message 49 of 54
Re: IP Profile
These are new stats this morning. IP Profile os 4.5 this morning. The errors have risen but nowhere near that of yesterday. Are these figures ok?
ADSL Line Status
Line state: Connected
Connection time: 0 days, 07:32:26
Downstream: 5.313 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 6.4 dB / 23.0 dB
Line attenuation (Down/Up): 48.2 dB / 31.5 dB
Output power (Down/Up): 19.9 dBm / 12.3 dBm
FEC Events (Down/Up): 494952 / 6
CRC Events (Down/Up): 96 / 2
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
HEC Events (Down/Up): 1784 / 2
Error Seconds (Local/Remote): 143 / 53
Hide details
This os router plugged into main socket via adsl v1 frontplate. Would replacing frontplate eliminate the errors completely or os this nowt to worry about
Message 50 of 54
Re: IP Profile
stats look ok and profile now correct for conenction speed.  I would leave the filtered faceplate as errors are ok at present - it would not eliminate them with a new faceplate
