crd1904
Message 51 of 54
Re: IP Profile
Excellent. Do the errors continue simply to add up as time goes on or do they "reset" themselves?
Message 52 of 54
Re: IP Profile
they will continue to accumulate but as long as not too many especially at night then it will be ok.  they should reset when conenction is reset.
crd1904
Message 53 of 54
Re: IP Profile
Hello
Well the hub has remained connected for almost three day with a steady 4.5 Bpms download which is fine. However it reset itself about two hours ago and these are the current data readings :
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 02:05:39
Downstream:5.344 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):5.4 dB / 25.0 dB
Line attenuation (Down/Up):48.4 dB / 31.5 dB
Output power (Down/Up):19.9 dBm / 12.4 dBm
FEC Events (Down/Up):489901 / 0
CRC Events (Down/Up):52 / 4
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):1069 / 3
Error Seconds (Local/Remote):461 / 113
Are these error reading too high? I t doesnt seem to be affecting the speed? Bit reluctant to alter anything!!
Regards
Carl
Message 54 of 54
Re: IP Profile
With only 2hrs connection time don't look bad especially if download ok and web pages loading ok - apart from forum which seems slow
Just stay connected as looks ok
