Sirgruffil
Message 11 of 13
Re: Sudden drop in BRAS rate
Thanks. Though I imagine that unlocking the modem breaks BT's T&Cs, so it would be difficult to direct them to the source of the problem using information detertmined that way?
sjtp
Guru
Message 12 of 13
I imagine that unlocking the modem breaks BT's T&Cs  I haven't found anything in the T&Cs that prevents it.  Even if you don't use the information with BT service, at least it gives you a much better idea of what is going on.
You need to be a little techie to do the unlocking, and to use the available scripts to take best advantage of the unlocking.
Sirgruffil
Message 13 of 13
Thanks, I think I could probably manage. I'll do some research.
