Message 1 of 20
Sudden drop in speed, no line fault detected?
Hi all,
our broadband speed has dropped significantly a few days ago and it hasn't gone back up.
Miraculously I got through to BT call centre, which ran some diagnostics and instructed me to reset my hub (4) to factory settings. Perhaps unsurprisingly, this doesn't seem to have helped.
As an example, in the past I was always getting between 4.5 - 7 Mpbs on download and around 0.9-1 Mpbs on upload (sometimes lower.)
All the tests from the last several days are similar to the below (as you can see they've just been going down):
00:29:50, 27 Jul.( 3900.200000) DSL noise margin: 5.90 dB upstream, 12.50 dB downstream
00:29:49, 27 Jul.( 3899.290000) DSL line rate: 312 Kbps upstream, 1304 Kbps downstream
Nothing has changed in the set up, position of the hub, any other devices that may have impacted this. The router is already in the optimal position.
I know my line is poor quality already, but this is quite a significant drop for what seems like no reason to me.
I also know there have been multiple issues with surrounding exchanges - is it possible something was reset during a "repair"??
Thank you in advance for any insight.
Tags (4)
19 REPLIES 19
Message 2 of 20
Re: Sudden drop in speed, no line fault detected?
has your hub been restating if it has that is why your noise margin has increased reducing your speed
Have you tried the quiet line test dial 17070 option 2 you should hear no noise if you can hear noise then it needs reporting to BT faults on 151 with no mention of broadband in the call
Message 3 of 20
Yes, the hub keeps restarting by itself.
I called the quiet line- no noise (or rather a VERY quiet hum.)
Moderator
Moderator
Message 4 of 20
Hi @jjaann,
I'll be able to take a look at your connection and run a few checks on your line. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Moderator
Moderator
Message 5 of 20
Hi @jjaann,
Thanks for sending over the details. I tried calling today, sorry I missed you. I've run a few diagnostics and can see the connection has recovered. The noise margin will adjust automatically if it remains stable. I've opened a case to monitor this but if you see any changes at your end please reply to my post and I'll look into it for you.
Cheers
David
Message 6 of 20
@DavidMThank you, I'm sorry I missed your call! The connection seems indeed to have recovered.
Thank you again for your speedy reply.
Moderator
Moderator
Message 7 of 20
Thanks for getting back @jjaann.
This looks like it's sorted but I'll keep the case open for another few days so you can monitor. If there's no change by Friday I'll close things off.
Cheers
David
Message 8 of 20
Thanks @DavidM. Unfortunately it's not looking great again:
21:42:22, 01 Aug.	( 104.020000) DSL noise margin: 13.20 dB upstream, 5.10 dB downstream
21:42:21, 01 Aug.	( 102.990000) DSL line rate: 443 Kbps upstream, 2679 Kbps downstream
Speedtest results are looking worse again (ca. 5 Mbps is what we normally get)
From the logs I can see someone from BT(?) was checking our line tonight.
Will be grateful for any advice.
Thank you
Moderator
Moderator
Message 9 of 20
Hi @jjaann and thanks for posting.
Sorry for the delay in getting back to you. Can you please run the speed test including the further diagnostics and post the results?
Cheers
David
Moderator
Moderator
Message 10 of 20
Hi @jjaann,
Sorry for the delay in getting back top you. I can see you have an engineer visit booked for tomorrow. Can you please post back and let me know how you get on?
Cheers
David
