Message 1 of 2
Sudden increase in DSL disconnects
I'm running a normally very stable g.fast line at around 300mbps being situated about 100m from the cabinet.
I've experienced 17 DSL disconnects (purple then orange lights on the hub, then immediate reconnection - total downtime about 5 mins) over the last 12 months. 11 of these disconnects have occurred since the beginning of June. This week alone I have had the broadband connection drop 5 times.
It always comes straight back, but naturally the disconnection is not good if you're working from home and on a teams call or the like.
I'm wondering if there might be something obvious I can do to try to mitigate this, or does it require further investigation?
1 REPLY 1
Message 2 of 2
Re: Sudden increase in DSL disconnects
as you have G.Fast and therefore still use the phone line have you check the line for any noise by dialling 17070 option 2  should be silent and best with corded phone
