alexh1
Message 1 of 16
Sudden increase in speed.
Hi.
So I noticed on Saturday night my broadband was rubbish and kept dropping out. When it finally came back on it was considerably faster. It we from 6mbs to 12mbs and upload went from .1 to 1.1. Has anyone any idea why this has happened and if it's likely to stay like it...?
15 REPLIES 15
john46
Message 2 of 16
Re: Sudden increase in speed.
most likely the DLM releasing more speed as it sees your line stabilising providing your connection remains stable it should stay or it could improve further
Webby
Message 3 of 16
Can you post the connection stats from the router?
alexh1
Message 4 of 16
I've had the same speed for two years ahah.
How do i post the stats?
alexh1
Message 5 of 16
Line state: Connected
Connection time: 0 days, 23:15:51
Downstream: 14.2 Mbps
Upstream: 1.188 Mbps
Webby
Message 6 of 16
What does http://www.dslchecker.bt.com show as the A speed range for your line?
alexh1
Message 7 of 16
3.5-7.5 mbs I normally get 6
Webby
Message 8 of 16
Perhaps a section of line has been replaced which was previously aluminium, or replaced with a thicker guage of cable.
alexh1
Message 9 of 16
They have been installing fibre all around us and they have recently put a green box in as I was on a EO line before is it possible they have turned it on....? Maybe fibre on its way?
Webby
Message 10 of 16
So you're not currently on Infinity?
Can you post up a copy of the wholesale dsl checker please and I'll might able to find out a bit more for you.
I suspect what's happened is that your copper line has been moved to the new cabinet and has reduced your distance to the exchange, therefore the speed has increased.
