alexh1
Message 11 of 16
Re: Sudden increase in speed.
BT BROADBAND AVAILABILITY CHECKER
Telephone Number 01600 on Exchange SKENFRITH is served by Cabinet 2
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 6 -- 4 to 8 Available -- -- -- --
WBC ADSL 2+ Annex M Up to 6 Up to 1 4 to 8 Available -- -- -- --
ADSL Max Up to 5 -- 3.5 to 7.5 Available -- -- -- --
Fixed Rate 2 -- -- Available -- -- -- --
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
This line is on a Market A Exchange.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact the Broadband supplier they want to take service from to arrange for the service to be migrated.
Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check.
Note:
Thank you for your interest.
Webby
Message 12 of 16
As you can see, you're no longer on an EO line, you're connected to cabinet 2.
The cabinet has the fibre and power connected to it, it's going through the commissioning process where it's all tested etc, and hopefully should be ready to take orders anytime in the coming weeks.
If you can find cabinet 2 (it's usually painted in white on the cabinet) and it's fibre twin (or it may be an all in one cabinet) keep an eye on it. When the lock on the AIO or fibre twin is changed to a high security silver lock, the cabinet will be active within a couple of days.
alexh1
Message 13 of 16
That's the best news you could of given me! I've waited since 2012 for fibre to come here!
alexh1
Message 14 of 16
The new cab is just on it own it's much closer than the exchange.
Webby
Message 15 of 16
There's quite a bit of work involved in installing the new cabinet. The speed increase will likely coincide with the cables being routed through the cab and possibly rerouted on a short route as I mentioned earlier.
Just keep a look out for the magic silver lock 🙂
alexh1
Message 16 of 16
Thanks for your help! Have a good evening.
