So you're not currently on Infinity?
Can you post up a copy of the wholesale dsl checker please and I'll might able to find out a bit more for you.
I suspect what's happened is that your copper line has been moved to the new cabinet and has reduced your distance to the exchange, therefore the speed has increased.
