As you can see, you're no longer on an EO line, you're connected to cabinet 2.
The cabinet has the fibre and power connected to it, it's going through the commissioning process where it's all tested etc, and hopefully should be ready to take orders anytime in the coming weeks.
If you can find cabinet 2 (it's usually painted in white on the cabinet) and it's fibre twin (or it may be an all in one cabinet) keep an eye on it. When the lock on the AIO or fibre twin is changed to a high security silver lock, the cabinet will be active within a couple of days.
