Oz1978
Message 1 of 7
Sudden problems connecting to BtWifi and BTOpenzone hotspots
I have a BT account and when round a friends house I usually log on to 2 bt hotspots (1 BTWiFi, 1 BtOpenzone-B). I've been connecting just fine to both for a couple of years now with hardly any issues at all, until recently when they both stopped providing a connection to the internet, I've tried connecting using my Ipad and Iphone (both using BTWifi app and not) and my friends PC but with no luck. All devices pick up a good strong signal and receive an IP address starting 10.*** just as they did before but get only limited connection. There is a BT-Wifi with Fon signal that I can connect to but its a very week signal and so intermittent and can only find it using the PC.
Is there anyone who can shed some light on this, I'm far from an expert but I'd have expected to get an IP address starting 169.*** if there was a problem with the hotspots internet connection, or does the 10.*** address just mean I'm connected to their router.
6 REPLIES 6
imjolly
Message 2 of 7
Re: Sudden problems connecting to BtWifi and BTOpenzone hotspots
An ip address starting with 10 is what I would expect when connecting to btwifi
Keith_Beddoe
Message 3 of 7
The 169 range is a local address that Windows uses if it cannot get a valid IP address. This results in a "limited" or "local" access message.
Oz1978
Message 4 of 7
Ah right thanks thats a bit clearer, so why am I recieving an IP address starting with 10.*** but only limited connection, I have tried connecting to both hotspots several times a day for the last couple of weeks, a couple of times I got the 169 but apart from that as I described.
Keith_Beddoe
Message 5 of 7
Try deleting any stored bt wifi and FON connections that you have connected to before. Then rescan again for the BT Wifi hotspot that you are trying to connect to.
Many devices get confused when there are a number of connections with the same SSID, and different BSSIDs. Clearing out old connections can fix the problem.
Oz1978
Message 6 of 7
I think I've already tried but I will try tonight when I go round there, thanks
Would this include removing the BTWifi profile from my Ipad?
imjolly
Message 7 of 7
The profile which you added to your ipad was to enable you to connect to the BTWIFI-X network
