CharlesElliott
Message 1 of 18
Sudden spate of ADSL sync drops - related to new BB/Calls package?
I have had stable 7Mb download internet for six months. This week, I have started having multiple sync losses per day. As a result, my connection speed has dropped to 1Mb and I am at a loss to explain why these drops have started happening. The only conincidental thing is that I moved my service to a combined call/BB package which was supposed to complete yesterday and I am still getting dropouts today. In reality, nothing actually changed as before/afterwards I am still on BB Option 3.
Any ideas/suggestions?
Tags (2)
17 REPLIES 17
Message 2 of 18
Re: Sudden spate of ADSL sync drops - related to new BB/Calls package?
can you post the adsl stats from your router may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z, if netgear enter 192.168.0.1) and run btspeedtester http://speedtester.bt.com and post the results.
are you connected to the NTE5 master or test socket or somewhere else? Do you have any phone extension sockets in your home?
Someone may then be able to offer help/assistance/suggestions to your problem
CharlesElliott
Message 3 of 18
So, I also notice that my SNR is bouncing around. Assuming a target of 6, my sync speed was looking close to 'optimal' on connection (!). However, last night I was connected at 1Mb down with a SNR of around 21dB.
12:55:32  24 Mar xDSL linestate up (ITU-T G.992.3; downstream: 776 kbit/s, upstream: 492 kbit/s; output Power Down: 17.9 dBm, Up: 11.6 dBm; line Attenuation Down: 43.5 dB, Up: 26.5 dB; snr Margin Down: 7.1 dB, Up: 5.9 dB)
I'm connected the master socket with i-Plate installed.
These are the current stats, although when it connected SNR was 7.1dB, is now 9dB 20 mins later.
Connection information
Line stateConnected
Connection time0 days, 0:23:39
Downstream776 Kbps
Upstream492 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.3
Latency typeInterleaved
Noise margin (Down/Up)9.1 dB / 7.2 dB
Line attenuation (Down/Up)43.5 dB / 26.5 dB
Output power (Down/Up)0.0 dBm / 11.6 dBm
Loss of Framing (Local)54
Loss of Signal (Local)8
Loss of Power (Local)0
FEC Errors (Down/Up)2330 / 4294966253
CRC Errors (Down/Up)0 / 2147480000
HEC Errors (Down/Up)nil / 1
Error Seconds (Local)47
My previous sync speed as late as Monday (4 days ago) was around 7.4Mb. Speedtester shows a very different picture now.
1. Best Effort Test: -provides background information.
Download Speed
209 Kbps
0 Kbps1000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 209 Kbps
 For your connection, the acceptable range of speedsis 400-1000 Kbps.
 Additional Information:
 Your DSL Connection Rate :776 Kbps(DOWN-STREAM), 492 Kbps(UP-STREAM)
 IP Profile for your line is - 750 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 20.94:33.66:45.62 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test: -provides background information.
Upload Speed
368 Kbps
0 Kbps492 Kbps
>Upload speed achieved during the test was - 368 Kbps
 Upstream Rate IP profile on your line is - 492 Kbps
Message 4 of 18
you are on adsl2 992.3 but your speed is very low for your attenuation.
have you tried just connecting to the test socket via filter with no accelerator - might help
CharlesElliott
Message 5 of 18
Re: Sudden spate of ADSL sync drops - increased noise on line?
I looked up some previous stats (September 2010)
ADSL line status
Downstream        4,544 Kbps
Upstream          1,079 Kbps
ADSL settings
Modulation                    ITU-T G.992.3
Latency type                  Interleaved
Noise margin (Down/Up)        14.5 dB / 5.6 dB
Line attenuation (Down/Up)    40.0 dB / 22.0 dB
Output power (Down/Up)        0.0 dBm / 13.1 dBm
So I was syncing at 4.5Mb with 14.5dB margin. BT then reduced the target back to 6 and I was up to 7.5Mb.
As of today I am syncing at 1.1Mb with around 7.5 dB - so it would definitely suggest that the noise margin on the line has decreased (i.e. noise has increased?) - right?
CharlesElliott
Message 6 of 18
Almost whilst typing that, my connection dropped! When it reconnected, it has the same speed but the noise margin is massively increased!
Downstream1,144 Kbps
Upstream1,032 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Noise margin (Down/Up)26.7 dB / 5.9 dB
Line attenuation (Down/Up)42.5 dB / 21.6 dB
Message 7 of 18
there has been a significant change though - exchange has changed you to adsl2+ 992.5.  a step in the right direction.  now if you can maintaina stable connection speed should increase and noise margin drop - may take a few days though.
hope this was due to change to test socket and no accelerator
CharlesElliott
Message 8 of 18
I hadn't noticed that......what is the difference....could there have been an exchange upgrade or is this just a re-profile?
Noise margin has remained high but line is as unstable as ever. And no, I haven't changed anything - I am still in master socket but with i-Plate.
CharlesElliott
Message 9 of 18
Here's my connection log from 08:56 to 11.00am. I lose count of the drops....
09:59:07  25 MarPPP link up (Internet) [86.183.172.73]
09:59:07  25 MarPPP CHAP Chap receive success : authentication ok
09:59:07  25 MarPPP CHAP Receive challenge (rhost = bras-red2.gi-b)
09:59:07  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 1064 kbit/s; output Power Down: 19.6 dBm, Up: 13.1 dBm; line Attenuation Down: 42.5 dB, Up: 21.5 dB; snr Margin Down: 6.3 dB, Up: 26.3 dB)
09:58:42  25 MarxDSL linestate down
09:58:23  25 MarxDSL linestate down
09:58:03  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 1039 kbit/s; output Power Down: 19.6 dBm, Up: 13.1 dBm; line Attenuation Down: 43.5 dB, Up: 22.1 dB; snr Margin Down: 6.3 dB, Up: 22.9 dB)
09:57:58  25 MarPPP link down (Internet) [86.182.97.26]
09:57:39  25 MarxDSL linestate down
09:57:20  25 MarxDSL linestate down
09:54:38  25 MarPPP link up (Internet) [86.182.97.26]
09:54:38  25 MarPPP CHAP Chap receive success : authentication ok
09:54:38  25 MarPPP CHAP Receive challenge (rhost = bras-red2.gi-b)
09:54:22  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 952 kbit/s; output Power Down: 19.4 dBm, Up: 13.1 dBm; line Attenuation Down: 43.5 dB, Up: 22.4 dB; snr Margin Down: 6.5 dB, Up: 17.2 dB)
09:54:21  25 MarPPP link down (Internet) [86.179.165.163]
09:53:58  25 MarxDSL linestate down
09:53:39  25 MarxDSL linestate down
09:46:21  25 MarPPP link up (Internet) [86.179.165.163]
09:46:21  25 MarPPP CHAP Chap receive success : authentication ok
09:46:21  25 MarPPP CHAP Receive challenge (rhost = bras-red2.gi-b)
09:46:07  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 1038 kbit/s; output Power Down: 18.9 dBm, Up: 13.0 dBm; line Attenuation Down: 43.0 dB, Up: 21.9 dB; snr Margin Down: 6.3 dB, Up: 23.8 dB)
09:46:02  25 MarPPP link down (Internet) [86.182.65.88]
09:45:43  25 MarxDSL linestate down
09:45:23  25 MarxDSL linestate down
09:43:32  25 MarPPP link up (Internet) [86.182.65.88]
09:43:32  25 MarPPP CHAP Chap receive success : authentication ok
09:43:32  25 MarPPP CHAP Receive challenge (rhost = bras-red2.gi-b)
09:43:16  25 MarPPP link down (Internet) [86.182.65.88]
09:43:14  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 945 kbit/s; output Power Down: 19.7 dBm, Up: 13.1 dBm; line Attenuation Down: 43.5 dB, Up: 22.5 dB; snr Margin Down: 6.5 dB, Up: 13.8 dB)
09:42:50  25 MarxDSL linestate down
09:42:31  25 MarxDSL linestate down
09:35:16  25 MarPPP link up (Internet) [86.182.65.88]
09:35:16  25 MarPPP CHAP Chap receive success : authentication ok
09:35:16  25 MarPPP CHAP Receive challenge (rhost = bras-red2.gi-b)
09:35:12  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 945 kbit/s; output Power Down: 19.7 dBm, Up: 12.8 dBm; line Attenuation Down: 43.5 dB, Up: 22.3 dB; snr Margin Down: 6.4 dB, Up: 14.6 dB)
09:34:52  25 MarxDSL linestate down
09:34:38  25 MarPPP link down (Internet) [86.180.169.209]
09:34:36  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 1044 kbit/s; output Power Down: 19.6 dBm, Up: 12.9 dBm; line Attenuation Down: 42.5 dB, Up: 21.6 dB; snr Margin Down: 6.3 dB, Up: 17.0 dB)
09:34:12  25 MarxDSL linestate down
09:33:53  25 MarxDSL linestate down
09:30:48  25 MarPPP link up (Internet) [86.180.169.209]
09:30:48  25 MarPPP CHAP Chap receive success : authentication ok
09:30:48  25 MarPPP CHAP Receive challenge (rhost = bras-red2.gi-b)
09:30:29  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 644 kbit/s; output Power Down: 20.1 dBm, Up: 12.9 dBm; line Attenuation Down: 43.5 dB, Up: 22.4 dB; snr Margin Down: 6.4 dB, Up: 12.3 dB)
09:30:09  25 MarxDSL linestate down
09:29:53  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 998 kbit/s; output Power Down: 19.6 dBm, Up: 12.8 dBm; line Attenuation Down: 42.5 dB, Up: 21.6 dB; snr Margin Down: 6.5 dB, Up: 16.6 dB)
09:29:49  25 MarPPP link down (Internet) [81.159.142.243]
09:29:29  25 MarxDSL linestate down
09:29:10  25 MarxDSL linestate down
09:22:39  25 MarPPP link up (Internet) [81.159.142.243]
09:22:39  25 MarPPP CHAP Chap receive success : authentication ok
09:22:39  25 MarPPP CHAP Receive challenge (rhost = bras-red2.gi-b)
09:22:27  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 237 kbit/s; output Power Down: 19.8 dBm, Up: 10.3 dBm; line Attenuation Down: 43.5 dB, Up: 22.4 dB; snr Margin Down: 7.5 dB, Up: 16.3 dB)
09:22:22  25 MarPPP link down (Internet) [81.159.142.32]
09:22:04  25 MarxDSL linestate down
09:21:44  25 MarxDSL linestate down
09:18:03  25 MarPPP link up (Internet) [81.159.142.32]
09:18:03  25 MarPPP CHAP Chap receive success : authentication ok
09:18:02  25 MarPPP CHAP Receive challenge (rhost = bras-red2.gi-b)
09:17:50  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 291 kbit/s; output Power Down: 19.8 dBm, Up: 10.3 dBm; line Attenuation Down: 43.5 dB, Up: 22.3 dB; snr Margin Down: 7.1 dB, Up: 15.4 dB)
09:17:45  25 MarPPP link down (Internet) [86.182.97.36]
09:17:26  25 MarxDSL linestate down
09:17:07  25 MarxDSL linestate down
09:13:06  25 MarPPP link up (Internet) [86.182.97.36]
09:13:05  25 MarPPP CHAP Chap receive success : authentication ok
09:13:05  25 MarPPP CHAP Receive challenge (rhost = bras-red2.gi-b)
09:12:54  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 484 kbit/s; output Power Down: 19.8 dBm, Up: 10.3 dBm; line Attenuation Down: 43.5 dB, Up: 22.3 dB; snr Margin Down: 7.1 dB, Up: 15.9 dB)
09:12:49  25 MarPPP link down (Internet) [86.173.174.114]
09:12:31  25 MarxDSL linestate down
09:12:11  25 MarxDSL linestate down
09:11:39  25 MarPPP link up (Internet) [86.173.174.114]
09:11:39  25 MarPPP CHAP Chap receive success : authentication ok
09:11:39  25 MarPPP CHAP Receive challenge (rhost = bras-red2.gi-b)
09:11:26  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 1056 kbit/s; output Power Down: 19.5 dBm, Up: 13.1 dBm; line Attenuation Down: 42.5 dB, Up: 21.6 dB; snr Margin Down: 6.5 dB, Up: 25.8 dB)
09:11:22  25 MarPPP link down (Internet) [86.178.13.150]
09:11:02  25 MarxDSL linestate down
09:10:43  25 MarxDSL linestate down
09:09:53  25 MarPPP link up (Internet) [86.178.13.150]
09:09:52  25 MarPPP CHAP Chap receive success : authentication ok
09:09:52  25 MarPPP CHAP Receive challenge (rhost = bras-red2.gi-b)
09:09:49  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 1005 kbit/s; output Power Down: 19.6 dBm, Up: 13.1 dBm; line Attenuation Down: 43.5 dB, Up: 22.2 dB; snr Margin Down: 6.4 dB, Up: 16.9 dB)
09:09:29  25 MarxDSL linestate down
09:09:15  25 MarPPP link down (Internet) [86.183.24.247]
09:09:13  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 1057 kbit/s; output Power Down: 19.4 dBm, Up: 13.1 dBm; line Attenuation Down: 42.5 dB, Up: 21.6 dB; snr Margin Down: 6.4 dB, Up: 25.5 dB)
09:08:48  25 MarxDSL linestate down
09:08:29  25 MarxDSL linestate down
09:02:45  25 MarPPP link up (Internet) [86.183.24.247]
09:02:45  25 MarPPP CHAP Chap receive success : authentication ok
09:02:45  25 MarPPP CHAP Receive challenge (rhost = bras-red2.gi-b)
09:02:43  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 1040 kbit/s; output Power Down: 19.5 dBm, Up: 12.9 dBm; line Attenuation Down: 42.5 dB, Up: 21.6 dB; snr Margin Down: 6.5 dB, Up: 25.9 dB)
09:02:24  25 MarxDSL linestate down
09:02:08  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 1035 kbit/s; output Power Down: 19.7 dBm, Up: 12.9 dBm; line Attenuation Down: 42.5 dB, Up: 21.6 dB; snr Margin Down: 6.3 dB, Up: 18.9 dB)
09:02:08  25 MarPPP link down (Internet) [86.183.24.69]
09:01:44  25 MarxDSL linestate down
09:01:25  25 MarxDSL linestate down
08:56:18  25 MarPPP link up (Internet) [86.183.24.69]
08:56:18  25 MarPPP CHAP Chap receive success : authentication ok
08:56:18  25 MarPPP CHAP Receive challenge (rhost = bras-red2.gi-b)
08:56:02  25 MarxDSL linestate up (ITU-T G.992.5; downstream: 1144 kbit/s, upstream: 344 kbit/s; output Power Down: 19.7 dBm, Up: 10.3 dBm; line Attenuation Down: 42.5 dB, Up: 21.6 dB; snr Margin Down: 8.5 dB, Up: 14.9 dB)
08:56:01  25 MarPPP link down (Internet) [86.183.24.117]
Message 10 of 18
the difference is that adsl2 992.3 is max 12mb whereas adsl2+ is 992.5 up to 20mb.  so the change has made your line look better quality to the exchange hence you are now 992.5
