Message 1 of 15
Sudden speed drop
Hey,
So I have had Fibre for a while now and for the first few months was more than stable at over 40Mbps, then it dropped to 33Mbps.....although not great and BT were unable to explain it, I was told "well it's within your expected speeds, so you will have to deal with it".....Fine, I understand how the business and what little rights the consumer actually has.
All of a sudden today, it has dropped to 23.93Mbps, which is even 4 Mbps below my minimum.
From my limited knowledge, I cannot see anything wrong with my stats so am looking for some help.....anyone got any ideas??  I should add that I haven't reported to BT yet, thought I'd try here first...had some great help on here before!
Product name:
BT Hub 6A
Serial number:
+084319+NQ71537210
Firmware version:
SG4B1000B540
Firmware updated:
20-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 25 Minutes 14 Seconds
Data rate:
8.93 Mbps / 23.93 Mbps
Maximum data rate:
8928 / 24124
Noise margin:
6.2 dB / 3.1 dB
Line attenuation:
23.2 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
29 MB Uploaded / 798 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-897S
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-897S
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:0D:E8:87
Software variant:
Boot loader:
7.33.1
14 REPLIES 14
Message 2 of 15
Re: Sudden speed drop
Message 3 of 15
You should not have displayed  your phone number on your last post, as its a public forum, and you are likely to get scam calls.
For your own protection, I have passed it to a moderator to edit, so your post will not be visible.
Please read the following page Privacy warning
Message 4 of 15
can you try connecting to the test socket with a filter even if you have a filtered master socket to see if that helps  when conencted to test socket can you post new stats  also check for any line noise    dial 17070 option 2  should be silent and best with corded phone
Message 5 of 15
Hey, I don't have a phone connected to the number anyway as it was always getting nuisance calls from pretty much the day it was connected and it's a second dedicated line for the internet, but I do appreciate you getting it removed for me. It is a master socket so there is no test socket, I will get it sorted when I get home tonight. Thanks very much mate, Scott
Message 6 of 15
There will be a test socket behind both removable sections.
Message 7 of 15
Brilliant. Thanks very much guys.
Message 8 of 15
Product name:
BT Hub 6A
Serial number:
+084319+NQ71537210
Firmware version:
SG4B1000B540
Firmware updated:
20-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 10 Minutes 17 Seconds
Data rate:
9.16 Mbps / 23.49 Mbps
Maximum data rate:
9157 / 23796
Noise margin:
6.2 dB / 3.1 dB
Line attenuation:
23.6 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
0 MB Uploaded / 1 MB Downloaded
Broadband username:
BT Wi-fi:
Active
BTHub6-897S
Smart (Channel 1)
BTHub6-897S
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:0D:E8:87
Software variant:
Boot loader:
7.33.1
Message 9 of 15
Hey,
Everything appears fine on the call, the stats above are on the test socket.
Thanks for the help.
Cheers,
Scott
Message 10 of 15
And now.....:(:(
Product name:
BT Hub 6A
Serial number:
+084319+NQ71537210
Firmware version:
SG4B1000B540
Firmware updated:
20-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 4 Minutes 13 Seconds
Data rate:
8.75 Mbps / 18.21 Mbps
Maximum data rate:
8751 / 17320
Noise margin:
6.1 dB / 2.4 dB
Line attenuation:
25 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
4096 MB Uploaded / 4097 MB Downloaded
Broadband username:
BT Wi-fi:
Active
BTHub6-897S
Smart (Channel 1)
BTHub6-897S
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:0D:E8:87
Software variant:
Boot loader:
7.33.1
