Message 11 of 21
Re: Superfast Fibre 2 Unlimited getting slower & slower
looking better but for how long?  still below estimated range but above handback
Message 12 of 21
I was about to say its stable but then it resetted again!
Message 13 of 21
Just resynced again that's 3 times in 5 mins do I need to report again or is it just DLM trying to find the reliable stats to use?
Message 14 of 21
There are no reported cab problems for Shepherds Bush but it certainly looks like you have a problem. Call in and get an engineer out.
Message 15 of 21
Looks like it could be a faulty port in the cabinet. Its not DLM.
Message 16 of 21
Been stable for 2.5 hours now I am still monitoring it before asking for an engineer incase its been corrected at the exchange. Presumably someone there was made aware or it auto switched to another port in the cab?
Message 17 of 21
Its nothing at the exchange and it won't have 'auto switched' at the cabinet. Unlikely, but somebody may have fixed the problem.
Message 18 of 21
Been stable for almost 11 hours now I will continue to monitor for another day or so.
Message 19 of 21
Hi @P-a-u-l,
Welcome back to the Community and thanks for taking the time to post.
Sorry that you are having problems with your connection.
I think the guys are right and you need to get an engineer booked or at least some tests done from our end.
I've sent you a Private Message with details on how you can get in contact with the mod team and we can take a look into this issue for you.
Matt
Message 20 of 21
Hi Matt,
Its been stable for about 7 days now. Just resetted itself (might be the cold weather outside! as it often does that if its get really cold). I will still monitor a bit longer before taking you up on your offer via PM.
Paul
