Message 1 of 13
Superfast Fibre 2, but should I move to Fibre 1
I currently have Superfast Fibre 2 but the real speeds are way below the estimates, and still way below the estimates for Fibre 1. If I moved to Fibre 1 to save a few pounds, would the real speeds stay the same, go down, or it's anyone's guess?
12 REPLIES 12
Message 2 of 13
Re: Superfast Fibre 2, but should I move to Fibre 1
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Message 3 of 13
The speed will stay the same if it is below 55M
Message 4 of 13
Thanks. It's way way below 55M, usually 40-44 or thereabouts.
Message 5 of 13
Can you post the connection stats from the hub.
HH6 Advanced settings/technical log.
HH5 Troubleshooting/helpdesk.
Also the result from the checker requsted by @Keith_Beddoe.
Message 6 of 13
BT BROADBAND AVAILABILITY CHECKER
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)60.44413.38.439.3Available----
VDSL Range B (Impacted)5837.712.87.432.4Available----
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 14.5--12.5 to 16Available--Yes
WBC ADSL 2+ Annex MUp to 14.5Up to 1.512.5 to 16Available--Yes
ADSL MaxUp to 8--7 to 8Available----
WBC Fixed Rate2 ----Available--Yes
Fixed Rate2 ----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date29-10-2018
Message 7 of 13
@bobdanbh
You should be getting a faster connection than you are at the moment, but it should become clearer once you post the connection speed.
Message 8 of 13
Seems a bit better today. I can never get the BT speed checker to work; Zoopla says 44.5 down, 8.1 UP.
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
Firmware version:
SG4B1000B540
Firmware updated:
26-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
6 Days, 2 Hours 12 Minutes 11 Seconds
Data rate:
10.15 Mbps / 49.00 Mbps
Maximum data rate:
10156 / 55069
Noise margin:
6.3 dB / 8 dB
Line attenuation:
20.5 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
3279 MB Uploaded / 28587 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
B 2.4 GHz wireless network name: H
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BH-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
Software variant:
Boot loader:
7.33.1
Message 9 of 13
Thanks to all. When we got fibre in our village I kept a detailed log of speeds. It started at 61M, and gradually declined to 40-44. An Openreach man came, it went up to 60.3, and has since declined again. Maybe the electrons are getting tired.
I'm just being mean, I suppose, in trying to save £7.50 a month. The galling thing is another place I know has Fibre 1 and the speeds are 55M always.
Message 10 of 13
It looks as though DLM has banded your line at 49M due to instability. Is there any noise on your line if you do a quiet line test on 17070?
