Message 1 of 7
Suposed Upgrade to infinity option2??
Hi,, ive upgraded to infinity option2 from option1 40/2..on my bt home page it states im on option2 but the speed tests dont seem to add up,,was told id get around 63.3meg down and upto 20 meg upload,
ive added info below of the test..does look right or has my line not been upgraded???
Thanks Dave..
1. Best Effort Test: -provides background information.
 Download Speed
 34 Mbps
0 Mbps38.72 Mbps Max Achievable Speed
Download speedachieved during the test was - 34 Mbps For your connection, the acceptable range of speedsis 12 Mbps-38.72 Mbps . Additional Information: IP Profile for your line is - 38.72 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 1.69 Mbps
0 Mbps20 Mbps Max Achievable Speed
Upload speed achieved during the test was - 1.69Mbps Additional Information: Upstream Rate IP profile on your line is - 20 Mbps
We were unable to identify any performance problem with your service at this time. It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly. If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
We have identified that you have additional services enabled on you broadband line, please click continue to run advanced service tests.
6 REPLIES 6
Message 2 of 7
Re: Suposed Upgrade to infinity option2??
Have you tried rebooting your kit mate? Both the OR modem and the hub 3?
Message 3 of 7
Daveym,
Welcome to the "unhappy camper" club,
Have you spotted that nearly all the threads on here are about the lack of speed increase since the supposed upgrade?
Guru
Message 4 of 7
Unfortunately tim1964, there will always be kinks in rolling out a new service, i'm sure B.T are well aware of it and looking into it.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
Message 5 of 7
"KInks"??
I thought that's what the testing before general release was supposed to be for.
BT whould have said "Sign up for Infinity 2 and IF your speeds go up to an acceptable level THEN we will start you on a new contract"
False advertising much?
Maybe some consumer group needs to run with this or maybe one of BT's competitors.
Imagine if Sky said "renew your contract with us for another year to receive double the number of channels for no extra cost " and then you find you actually get less channels than you did before  !!
They would never get away with saying "we ESTIMATE that you will get more channels ......"
Customer relations nightmare.
Guru
Message 6 of 7
There are some things than can be added to your service that are definite. Unfortunately when it comes to fibre optics or just an ordinary copper line there are more variables involved.
They are estimates because they have to be as every line is different, and they are only up to speeds as well.
If B.T were aware of this issue, i'm pretty sure they wouldn't roll it out. Sometimes pre testing doesn't compare to a full scale upgrade.
Message 7 of 7
Yep tried resetting both,,ive got the hhub 2
