Message 1 of 1
Suresignal 1.0 does not work with HH 2.0 after house move
Moved house and changed postcode on Suresignal. Vodafone tells me the problem is on the BT side. Am using same router, and did previously also have BT Openreach - all worked fine, but Suresignal will not connect in new location. Vodafone says the following config is required. I have no idea what any of it means. Any help most appreciated!
Dear Customer,
Requires internet specs of:
DL 1Mbps
UL 0.36 Mbps
Kindly advice your Internet Service Provider to apply the following settings to your Ro
uter:
First of all, please verify with your ISP that they are using PPPoA as authentication and not PPPoE as the Vodafone Sure Signal only works with P
PPoA
1- Assign a static IP to the Vodafone Sure Signal Device using the MAC Address on the back of the Sure Signal Device
2 - Open the following ports
(Incoming & Outgoing) for the Sure Signal assigned IP Address:
Port 50 - TCP/UDP
Port 53 ? TCP/UDP
Port 67 ? UDP
Port 68 - UDP
Port 500 - UDP
Port 450
0 - UDP
Port 123 ? UDP
Port 8 ? TCP/UDP
Port 1723 - TCP and UDP
Port (33434 ? 33445) - UDP
3- Make the Vodafone Sure Signal IP Visible
Kind Regards,
Vodafone
Kindly advice your Internet Service Provider to apply the following settings to your Router:
they are using PPPoA as authentication and not PPPoE as the Vodafone Sure Signal only works with PPPoA
2 - Open the following ports (Incoming & Outgoing) for the Sure Signal assigned I
P Address:
Port 50 - TCP/UDP
Port 53 ? TCP/UDP
Port 67 ? UDP
Port 68 - UDP
Port 500 - UDP
Port 4500 - UDP
Port 123 ? UDP
Port 8 ? TCP/UDP
Port 1723 -
TCP and UDP
Kind Regards,
Vodafone
Tags (2)
