Message 1 of 18
Swann CCTV
Hi, I'm not sure if I have the correct forum page so if I'm in the wrong section could you please redirect me.
I have just bought a Swann security CCTV system for my garage, I need to connect the DVR to the internet but it can only be done via an ethernet cable from the router.
Our wireless router is too far away from the DVR to plug it in as the garage is at the bottom of our very long garden, I was thinking along the lines of buying a router that would pick up BT hotspots and connect that way.
Does anyone have any suggestions or advice please
17 REPLIES 17
Message 2 of 18
Re: Swann CCTV
@brian22cairns
Which BT Home Hub are you using?
Message 3 of 18
Re: Swann CCTV
Fibre with BT Halo 2
Message 4 of 18
Re: Swann CCTV
This should help. It will provide an Ethernet link.
https://shop.bt.com/products/bt-broadband-extender-600-kit-084284-BVFL.html
An even better option would be to run an External Ethernet cable.
Message 5 of 18
Re: Swann CCTV
I looked into this but I can't see it working as our router will be nearly 1/4 mile away from garage, it also rules out an external ethernet cable.
That's why I was thinking along the lines of a router that we can wirelessly pick up our account via HotSpot so we can then just run a standard 1 metre length ethernet cable from that router to the DVR
Message 6 of 18
Re: Swann CCTV
Routers don't pick up a hotspot, they transmit it and only when connected to the internet.
There is no way you are going to connect anything 1/4 mile away in any case, either by Ethernet or wifi.
Message 7 of 18
Re: Swann CCTV
If its that far away, they you would be better to get a separate broadband connection, or perhaps a 4G router with an unlimited data package.
Message 8 of 18
Re: Swann CCTV
I've been told to use an old laptop with a WiFi adaptor dongle and connect the laptop and DVR using the ethernet cable, thing is it would mean the laptop being on 24/7
Message 9 of 18
Re: Swann CCTV
Wifi will not travel a quarter of a mile.
If you could detect a good signal, the a wireless access point operating as a wireless client, would convert the wifi signal to an Ethernet connection.
Like this https://www.tp-link.com/uk/home-networking/access-point/tl-wa901n/
Operating in client mode, it receives an incoming wireless signal, and presents it on an Ethernet connection.
Message 10 of 18
Re: Swann CCTV
You need to connect to the Internet. Because of the location to your garage being so far from your house you would need to get a sperate Internet feed into your garage.
This would mean either you pay for phone/broadband line to be installed in the garage so that you can purchase a suitable broadband package or you purchase a mobile broadband router/dongle and package.
Rather than using a laptop you should get a mobile broadband router and your CCTV could connect directly to that. This CCTV system would be an independent system and not part of any CCTV system that you may have for your house.
