gregsonline
Message 11 of 17
Re: Swapped to BT - Terrible Speed #2
also how can it be network congestion when if you restart modem speed is back to normal but slow again after few hour up time ..
Webby
Message 12 of 17
You don't seem to understand how the network works.
You're right in that the line, cabinets and exchanges are all Openreach (not BT) responsibility and all data to the exchange follows the same path. There is no problem here, the fibre links back to the exchange usually have at least 2.5Gb/s capacity, with the potential of a LOT more. This is not where the bottle neck is.
As I've said, Sky and a few other providers such as TalkTalk use a different backhaul from the exchange.
When the fibre connection from the cabinet gets to the exchange, the data is handed over to the relevant layer 2 switch for the onward connection. BT use a BT Wholesale backhaul, as do the likes of PlusNet. Sky and TalkTalk, amongst other providers don't, so their customers are routed differently once they hit the layer 2 switch in the exchange.
gregsonline
Message 13 of 17
so bt know this also but choose to string poeple along and tell you all is working as it should  if they cant provide speeds stated at start of contract because of congestion or drops below VDSL Range A  should be released from contract .my speed drops any time of day till it is dial up speed and i have restart modem then its ok for a while then starts to slow again.
Webby
Message 14 of 17
BT as in your ISP wouldn't know about it, least of all the sales advisors.
The ranges on the DSL checker are relevant to sync speed, not throughput.
I agree that if the issue can't be resolved within a reasonable time frame, then you should be free to leave without penalty.
Have you considered trying a third party router to rule out the home hub?
gregsonline
Message 15 of 17
when i say bt i mean open reach as well
gregsonline
Message 16 of 17
modem on the way tp link 9980
Webby
Message 17 of 17
See what the results are with that. If the issue resolves itself with a reboot, it's very very, very unlikely to be network congestion.
