Message 11 of 16
Re: Swapped to BT - Terrible Speed
Sky use their own backhaul from the exchange where all others use the BT Wholesale network this problem will be being investigated by BT Wholesale not Openreach as it is not an Openreach or BT Retail remit to resolve
Wholesale will be working on a fix but depending on the fix this can sometimes take some time to resolve
Message 12 of 16
Ah. I wasn't aware that Sky used their own backhaul connection and apparently neither do BT online support as they stated that I must have had the issue with Sky as they all use the same backbone... That would make much more sense and almost certainly point towards that as being the issue.
My only issue now is that no-one can give me a resolution date so it is a question of do I hang on paying for an unuseable service or find a way to exit the contract. If they cannot provide a resolution date and release me from the contract I think a call to OFCOM will be in order.
It just shouldn't take this much effort and consternation to obtain a reliable service.
Message 13 of 16
OFCOM do not get involved in individual complaints
only BT Wholesale will be aware of a fix date and that depends on the complexity of the fix
getting released with no charge may be difficult as it is connection (sync ) speeds that are used not download speeds as they can constantly vary
Message 14 of 16
I know OFCOM don't deal but they provide you with details of an arbitrator and although BT may state they operate on line speed they have signed up to the voluntary code which talks about significantly reduced download speeds...
Message 15 of 16
correct you need to give BT time to resolve the problem and to obtain a deadlock letter from BT you need to give them 8 weeks which you can then send to the communications ombudsman
Moderator
Moderator
Message 16 of 16
HI @ithebebs,
Thanks for taking my call today. I'm really glad I was able to get this sorted for you. Please post back if you have any other problems and we'll be happy to help.
Cheers
David
