Hi I've been moved over to fiber, this was done by BT not a request. My speed has dropped from 8-9.5MBPS to 5.8.
I was told my estimate speed would be 2-6 in an email i received but this seems silly considering my copper ADSL2+ was almost double the speed.. Not only is it slower my ping is higher by around 15ms.
I'm guessing this has to do with the line length, but I've seen a cabinet in my village which is around half a mile away surely this could be used? Any help or suggestions would be appreciated.
Enter your phone number and post results. Remember delete number. https://www.dslchecker.bt.com/
Post hub stats advanced settings then technical log information
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper High Low High Low Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)ADSL Availability DateWBC SOADSL Availability DateLeft in JumperObserved SpeedsVDSLADSLOther Offerings
Availability Date
Premise environmentStatus
VDSL Range A (Clean) | 6.3 | 2.5 | 1.2 | 0.8 | 1.9 | Available | Available | -- | |
VDSL Range B (Impacted) | 6.3 | 2.5 | 1.1 | 0.8 | 1.8 | Available | Available | -- | |
FTTP on Demand | 330 | 30 | -- | Available | -- | -- | |||
WBC ADSL 2+ | Up to 5 | -- | 4 to 8.5 | Available | Available | -- | |||
WBC ADSL 2+ Annex M | Up to 5 | Up to 1 | 4 to 8.5 | Available | Available | -- | |||
ADSL Max | Up to 3.5 | -- | 3 to 7.5 | Available | Available | -- | |||
WBC Fixed Rate | 2 | -- | -- | Available | Available | -- | |||
Fixed Rate | 2 | -- | -- | Available | -- | -- | |||
Max Observed Downstream Speed (Mbps) | -- | 9.73 | |||||||
Max Upstream Observed Speed (Mbps) | -- | 1.18 | |||||||
Observed Date | -- | 2020-03-09 | |||||||
VDSL Multicast | -- | -- | -- | Available | -- | -- | |||
ADSL Multicast | -- | -- | -- | Available | -- | -- | |||
Bridge Tap | U | ||||||||
VRI | N | ||||||||
NTEFaceplate | N | ||||||||
Last Test Date | 09-03-2020 |
You need to phone BT move back to adsl2 as you will have better connection. There should have been a phone number to contact if you didn't want the change to fibre to go ahead
openreach will not move your cabinet just so you can get a better broadband speed. This has been covered numerous times on the forum
Your router stats look fine and you are at the top end of your VDSL estimate. BT have moved you from ADSL to FTTC as they are going to be removing ADSL equipment from the exchanges. For some people such as yourself this will result in slower speeds. I can only suggest you look at 4G instead - if you can't get 10Mbps download over 4G then you could apply for USO but you are likely to get at least 10Mbps on 4G.
it will be a while before you cannot get adsl broadband so I would phone BT on the number on the BT email and move back to adsl2. Sooner the better
there are some similar posts on the forum with customers same problem as you. Use search facility
@brookheatherwrote:Your router stats look fine and you are at the top end of your VDSL estimate. BT have moved you from ADSL to FTTC as they are going to be removing ADSL equipment from the exchanges. For some people such as yourself this will result in slower speeds. I can only suggest you look at 4G instead - if you can't get 10Mbps download over 4G then you could apply for USO but you are likely to get at least 10Mbps on 4G.
2025 before they even start.
I was told it would be more reliable and stable, but i'm still getting packet loss while gaming, around 2-15% in intervals like i had before. i'm guessing my line is at fault still, i can live with 5Mbps if it means fiber is more stable..and the ping is in general lower? i used to be on fast path on ADSL and i'm sure fiber doesn't have this option does that mean its filtered like it would be on interleaved?
Thanks James
Get onto them to be put back onto ADSL until they can offer a better service. Don't listen to the sales **bleep**!
