swiftz
Message 1 of 4
Switching from BT to Plusnet cabinet
I'm moving from BT Unlimited Infinity 1 (up to 52MB) to Plusnet Unlimited Fibre Extra (up to 76MB) but do I keep my current place in the cabinet or do I get moved to a different place in the cabinet or to a different one? As my line with BT has been fine and stable but switching to Plusnet due to better prices.
3 REPLIES 3
Webby
Message 2 of 4
Re: Switching from BT to Plusnet cabinet
As far as I know, you're switched to a different port in the cabinet.
swiftz
Message 3 of 4
Are all the ports in the cabinet the same as in stable? I joined BT when the cabinet just had fibre installed so I should be at the bottom I believe but after the switch, I should be in the middle/top.
Webby
Message 4 of 4
The port is irrelevant
