Message 1 of 5
Switching to BT TV - Do I Need to Tell Sky or do BT sort it all?
Hi Guys
Thinking of switching from Sky TV to BT TV. Since Nov 2016 we have BT Infinity broadband after moving from Sky.
If we moving to BT TV as well do we need to tell Sky we are cancelling and changing to BT TV or will it all be done for us?
Any minimum contract we have with Sky has passed.
Thank you.
4 REPLIES 4
Sage
Message 2 of 5
Re: Switching to BT TV - Do I Need to Tell Sky or do BT sort it all?
You will have to inform Sky yourself.
Message 3 of 5
Ok so in terms of order of doing things..
Should I order BT Tv first then cancel Sky?
Whats the lead time for BT TV to be in place? I already have BT broadband.
If I cancel Sky they are always likely to offer some deal😀
Sage
Message 4 of 5
I would think the best way would be to order BT TV first as you will then know when the equipment shoud arrive.
Then again if you don't want the services to overlap do the opposite.
The final decision is yours.
Message 5 of 5
Ok thanks all for the advice
