TitusC
Message 1 of 9
Sync BT Yahoo Mail and Outlook?
I use Microsoft Outlook 2007 on my desktop and BT Yahoo Mail via a web browser when I'm away from home.
Does anybody know how I can sync my contacts and calendar between BT Yahoo Mail and Outlook?
I know that I can import and export, but I want to sync. There used to be a Yahoo sync Outlook add-in but that isn't available anymore.
Any help would be appreciated.
Thanks.
Tim
Tags (3)
8 REPLIES 8
Distinguished Guru
Message 2 of 9
Re: Sync BT Yahoo Mail and Outlook?
Before you spend too much time on it, you should be aware that BT Yahoo mail will be switched off some time later this year.  BT are migrating across to a new mail provider.
See http://bt.custhelp.com/app/answers/detail/a_id/44789/?s_cid=con_FURL_email_newemail
TitusC
Message 3 of 9
Many thanks for pointing this out. I thought BT were just introducing a new launch page. I wasn't aware that it would be a whole new mail service.
Hopefully the new service will allow me to sync my contact and calendar entries.
Tim
Message 4 of 9
I doubt very much that there will be a calendar option, I would imagine it will be just a basic e-mail service, like the early days of BT Internet.. Only Google have full integration, as far as I am aware.
Distinguished Guru
Message 5 of 9
According to the new mail page, there will be a calendar on the new system:
Will my Calendar entries be retained and carried across to the new email service?
Yes these will be migrated across. However, there will be some calendar settings that we can't replicate on the new platform.
Message 6 of 9
Thanks for that info, I have not seen any offerings from Critical Path, so it will be a case of wait and see whether it will allow synch.
Message 7 of 9
Re: Sync BT Yahoo Mail and Outlook > EVO Collaborator for Outlook
If you are still looking for a solution to keep Yahoo synced with Outlook I can suggest the plug-in for Outlook that I have been using since 2014.
EVO Collaborator for Outlook or ECO for short. With that I sync my calendars, contacts and emails between Yahoo and Outlook as well as other services such a Gmail.
You can check out this blog post that covers the syncing process with this program and see if it can help you or not.
http://jeffconstatine.tumblr.com/post/98611150497/import-export-and-synchronize-yahoo-carddav-and
Message 8 of 9
Tried out the trial version of EVO Collaborator for Outlook.
Works well for me and Ill probably end up buying it as it solved all the issues I was having.
jbyng
Message 9 of 9
I dont think this ever happened
