imjolly
Message 11 of 25
Re: Sync speed gradually reducing
john46 I don't think it is banded at present just has a noise margin of 15db   if it continues to reset then banding will be next
VanMildert
Message 12 of 25
Tested using 17070 with cordless phone both using home extension wiring and direct via the test socket and there is low level but perceptable "white" noise in the background and no hum in both cases.
imjolly
Message 13 of 25
it would be better if you can borrow a corded phone and check quiet line test just to confirm that not phone causing the noise before you report a phone fault
VanMildert
Message 14 of 25
Tested with corded phone and the noise is still there.
How do I go about reporting a fault? What information are they likely to need from me?
imjolly
Message 15 of 25
you need to phone 151 and report a phone fault  and do not mention broadband  just ypou have a noisey phone line
VanMildert
Message 16 of 25
Contacted 151 as you suggested and no fault was discovered on the line but it was agreed to send out an engineer to checlk the phone socket. Engineer arrived this morning and diagnosed a fault with the socket and replaced it.
Line sync dropped as low as 7.9 but has now recovered to 10.4. How long should I expect to wait before peak speed is achieved (somewhere between 16 and 18 based upon previous experience)?
Thanks for your help which is really appreciated.
john46
Message 17 of 25
can you please repost the adsl stats from your hub
VanMildert
Message 18 of 25
Stats taken from last occasion yesterday (26 Feb) when router restarted and after the engineers visit:
15:49:13, 26 Feb. (16152.680000) DSL noise margin: 5.90 dB upstream, 15.30 dB downstream
15:49:12, 26 Feb. (16151.660000) DSL line rate: 851 Kbps upstream, 10359 Kbps downstream
Is there any other data that you require?
imjolly
Message 19 of 25
Your noise margin is very high at 15db as normal about 6db. If you can maintain connection for 3+ days then repost the 2 lines of stats and we can see if mods will reset noise margin back to 6db
VanMildert
Message 20 of 25
Just updating after about a week after the engineer replaced the main phone socket.
Latest figures from hub event log are as follows:
15:48:08, 07 Mar.(297527.270000) DSL noise margin: 5.90 dB upstream, 0.80 dB downstream
15:48:04, 07 Mar.(297523.240000) DSL line rate: 964 Kbps upstream, 18070 Kbps downstream
All seems to have settled down.
Thanks for all the helpful advice.
