Message 1 of 7
Synchronizing Calendars and Contacts in Outlook
Hi, does anyone know if it is possible (and how please) to synchronise the Clandar and Contacts stored in BT Mail with the Calendar and Contacts in Outlook (Office 2013)?
Many Thanks
6 REPLIES 6
Message 2 of 7
Re: Synchronizing Calendars and Contacts in Outlook
Many Thanks
You can export the calendar to an ics file.
When the BT mail calendar is open, goto actions > export. The file type for export is ics.
In Outlook 2013 goto file > import / export > select your option and import ics file.
It was functional when I last looked, although one poster says that calendar export is not available in the old BT Yahoo mail.
It should be a similar operation for contacts, but I haven't tried.
Message 3 of 7
Synchronised contacts to Outlook 2007 2 days ago using the "File/Import/Export" method above.
Message 4 of 7
Thanks for the answer!
Much appreciated.
Recognised Expert
Message 5 of 7
Glad it worked, but it's not really synchronising, is it?  Every time you make any changes or additions, you'll have to go through the same manual export/import kerfuffle again.
Instructions for doing it properly are here, but I've no idea whether Outlook supports the necessary protocols.
Message 6 of 7
That helps towards clearing up a mystery. The present (steam) method works for me until there's a better method available.
It looks as though it can and will work on Outlook. There's just a possible minor task of having to switch Outlook accounts to gain access to the newly created account in order to perform the sync, but it's a lot simpler than the import / export routine.
I don't store calendars or contacts on BT Mail, as there's no need, just being home based. Going by their recent improvement in blocking spam, the service seems to be quite secure - secure enough to store contacts and calendars, so you have all in one place, in accordance with the new trend of cloud storage.
Message 7 of 7
how about the other way round? Can I import the outlook 2010 calendar entries into the BT Mail calendar? And keep them in sync?
Cheers
Geoff
