norfbert
Message 1 of 4
Synergy 6500 Quad
I have a new Synergy 6500 Quad and one handset will not work properly. It continually says "searching for base", "no link to base" and "Please check base" when I dial a number. I have tried this handset in all three remote bases. Gone through the prodedure of registering it with the main base all to no avail. Help me please.
3 REPLIES 3
SeanD
Community Manager
Community Manager
Message 2 of 4
Re: Synergy 6500 Quad
Hi Norfbert,
Welcome to the forum.
You have probably already checked the user guide but if not it can be found from this link, BT Synergy 6500
If you cannot find the answer to your problem in the full online user guide, then please call the free Helpline on 0800 145 6789.
Cheers
Sean
Daiben
Message 3 of 4
Hi, just wondering whether your problem was solved, and if so how? my phones have now developed the same problem I believe after a recent power cut.
I understand that your problem happened a few years ago, and that you are probably not an active member of the forum any more! but I am desperate to get this problem solved, thanks
Devon_Dave
Distinguished Guru
Message 4 of 4
@Daiben. The original poster has not been on the forum for a few years now
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
