rayjon
Message 1 of 2
Systems Tray
Hi.
My first query since coming to BT.
I user have in my systems tray an icon to list connection, I had a message arrow pointing to Internet problem and to downplay a repair, every thing worked all right then I noticed the icon was missing and cannot see what is my connection I use to have Like BT Home Hub connected, and BT-Fond & Openzone.
In Internet connection icon what or where I am connected to.
I hope you understand my message.
Thank you.
1 REPLY 1
Distinguished Guru
Distinguished Guru
Message 2 of 2
Re: Systems Tray
Check that the system tray still customised to show the icon. 1. Click the double arrow; 2. click "Customize"; 3. in the list which appears find the icon (I assume you mean the one that looks like pan pipes); 4. make sure that the drop-down list is set to "Show icon and notifications".
