Message 1 of 4
TCP and UDP ports for sure signal box 2
I am trying to connect sure signal box (2).  Vodafone sent me a list of ports but not sure how to use them.  Tried 8 TCP UDP which is the first one 9 more to go.  Not sure if I am doing it correctly. Can anyone help please
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: TCP and UDP ports for sure signal box 2
Hi Jeannie45,
Welcome and thanks for posting!
Check out this link - Does the BT Home Hub allow game and application sharing/port forwarding
Post back to let me know if this helps.
Cheers,
Robbie
Message 3 of 4
Hi Robbie.  Yes it does.  Been down that route. Problem I have is the list of protocols that vodafone sent me.  Tried inputting them but not sure if I was doing it right.  Not a technophobe but do get a  bit stuck on the more complex stuff.
Moderator
Moderator
Message 4 of 4
Hi Jeanne45,
Thanks for posting back!
There is third party software you can download that can test if the ports are open but I can't advise from here. Hopefully one of the community pops along but failing that, try a quick google search.
Cheers,
Robbie
