MadRob
Message 1 of 3
THE GREAT VALUE STARTER PLAN
There are 3 of us at home. We would all like the above plan at £5 as we only use calls and texts. I know the plan isn't compatible with the Family Sim packages but I'm confused as to how many of the Value Starter Plan sims I can purchase. Is it only one per household or can we add further seperate sims to this plan for other members of the household? Any insight or advice will be greatly appreciated. Thanks.
2 REPLIES 2
Leigh320
Message 2 of 3
Re: THE GREAT VALUE STARTER PLAN
You can order 3 separate sims on the same account. I think you will have to place 3 separate orders.
I had 2 of the £5 sims when I first started with BT Mobile.
I believe there is a limit of 5 sims per account but might be wrong on that one.
MadRob
Message 3 of 3
Thanks for that @Leigh320
Had another look at the website and I reckon you are correct with your answer. Only looking the 3 sims so should be fine here. Kind regards.
