I see they have a new one out...
Question, does it work with the Youview IP channels?
It looks a bit nicer than their old model but cost more 😞
Many thanks.
Looks like it, according to the datasheet IGMP supported. http://uk.tp-link.com/res/down/doc/Archer_VR900_V1_Datasheet.pdf
We expect a full report.
Not a good start
Looking back at the history of the previous model it looks as though it took a couple of firmware upgrades over the course of six months for it work properly, you'd think they would be ahead of the game this time round?
It's a pity because otherwise I'd have ordered this up today on the Amazon £10 off £50 deal ;-/
TD-W9980 Firmware release notes
Got an email from them today...
[quote]Thanks for your reply.
Our engineer are looking into this issue. We will inform you once we figure this out.
Thank you for your patience![/quote]
Only one engineer, no wonder the box is still on the original firmware release from April.
For information, the Media Server option works better than the TD-W9980 which would only index 1000 items.
This one seems to have a limit of just under 10,000 tracks as it only shows 9208 items out of my 16,497 mp3's
I have put the TD-W9980 back in place and YouView worked straight away...
Seems crazy earlier models work ok but the new one doesn't!!
@Automan According to the kitz forum there is a v2 version due out shortly so that might address the problem. Might be worth you asking on kitz if anybody has managed to get IPTV working.
