Automan
Message 21 of 43
Re: TP-LINK Archer VR900 AC 1900 Wireless Dual Band Gigabit VDSL2/ADSL2+ Modem Router
No problems with the Beta with Youview but error packet count on the modem goes up into the hundreds in under 24hours.
My old TD-W9980 never displayed anything but zero.
Also with the VR900 with both official and beta firmware the Upstream Line Attenuation db value is always blank.
VR900 High Error Count And No Upstream DB
No Errors On Old Model
Automan
Message 22 of 43
One more thought/question is BT Inifinity Annex A or B?
Or perhaps it does not matter?
One of my TP-Links goes for 'B' and the VR900 'A' with not even an option to try 'B'
baconnugget
Message 23 of 43
Decided to order this as the price is £128.95 on Amazon 🙂
Automan
Message 24 of 43
Still not happy with the high error rate and missing data :(
High Error Rate And No Upstream Line Attenuation
Anyone else get 0db for Upstream Line Attenuation or a high error rate?
zarf2007
Message 25 of 43
it must be specific to you line, i have 0 errors downstream and a hundred or so upstream but stability is rock solid....im not worried about the few upstream as compared to the many hundreds of thousands successfully transmitted this is a drop in the ocean...
baconnugget
Message 26 of 43
I just setup the router with the July 2015 firmware working well so far.
SmellyPants
Message 27 of 43
Anyone tried out the v1.150909 Firmware released on Friday :-?
New Features
  • * Devices' name can be modifid in your WLAN or LAN.
  • * G.INP is supported
  • * The PIN code of 3/4G SIM card can be unlocked automatically
  • * HTTPS URL filtering supported in Parental Control
  • * Update and the ISP's list for xDSL configuration,and sky(MER)_VDSL is added to the list.
  • * IPV6 tunnel function is added.
Bug Fixed
  • * fix the bug that BT Youview can't be get by BT user.
  • * fix the bug that URL filtering fails.
  • * fix the bug the NAT Loopback fails.
  • * fix some bugs about the User Interface
Automan
Message 28 of 43
Will do tonight but as I have cancelled my Youview (price rise) the fixes no longer matter to me...
Edit: Installed but still think it is odd the attenuation value is zero and still getting errors (none with other model)
Link Status With New Firmware
baconnugget
Message 29 of 43
I just installed the new firmware, my attenuation value is zero too. The previous version wasnt zero.
Automan
Message 30 of 43
New firmware out now which displays the line status correctly....
New Features/Enhancement:
1. Added Tether support.
Bugs Fixed:
1. Fixed the bug that the value of upstream line attenuation in the Status page was always zero
http://uk.tp-link.com/res/down/soft/Archer_VR900_V1_151111.zip
